Newbie rmain_emb
Migrating from Actel APA600 to Xilinx FPGA
I've been asked to recomend a suitable target to migrate from an Actel APA600 to a Xilinx FPGA product. The APA600 is in a PQ208 package, so IO requirement is pretty tame. The design is pure logic (there is no need of DSPs or high speed digtial IOs, embedded MACs, etc. ).
Can I assume Xilinx "Logic Cells" are roughly equivalent to Actel "Tiles"?
If so, the APA600 has 600,000 "Tiles", so I'd be looking at something like a Virtex-6 LXT, maybe XC6VLX550T, even though the pin count is WAY excessive (840 or 1200)?
R. Main
Instructor
Instructor
Re: Migrating from Actel APA600 to Xilinx FPGA
The Spartan 6 LX25 should be a safe bet for logic capacity.  Perhaps you should check other
requirements like I/O standards (Spartan 6 supports a variety of standards up to 3.3V), and
speed.
Depending on your LUT vs flip-flop usage, it is likely that you could fit the design in a smaller
part.  You might want to try using the ISE webpack to see how your design synthesizes into
Spartan 6 LUTs and flip-flops.  Of course, how easy this is depends on how much you made
use of Actel-specific library elements.  A pure HDL design should port fairly easily.  Be careful
when using the "Logic Cells" numbers in the Spartan 6 Family Overview.  The actual number
of 6-input LUT's is smaller than the Logic Cells number, but there are twice as many flip-flops
as LUT's.  So going from a more standard 4-LUT+Flop architecture is not a one-to-one
conversion to logic cells.
-- Gabor
-- Gabor
Newbie rmain_emb
Sorry, the APA600 has 600,000 GATES, or 21,504 "Tiles".
If Tiles = Flip Flops, then the Spartan 6 LX would work, maybe a XC6LSX25?
Instructor
Instructor
speed.
-- Gabor
-- Gabor
Instructor
Instructor
I forgot to add that when you look at the device / package table in the S6 family overview,
the devices in the same package are footprint-compatible.  So you could for instance
start with a LX25 and if you find that your design fits in a LX16, then you could just replace
the chip without redesigning the board.  The device pinout tables list devices by
package, and indicate if some I/O pins are not available for certain footprint-compatible
parts.
-- Gabor
-- Gabor
