NGDBUILD warning - ConstraintSystem - A target design object for the Locate constraint could not be found ???!!!
hi,
i have a constraint in my ucf file - NET "datain" LOC = AL37;
i use synplify to synthesize my design. i do a constraint check and the above constraint is fine.
after synthesis, i take the edf file and put it in xilinx ise 14.1 for implementation/bitgen. i use the same ucf (which i used for synplify synthesis).
the entire process completes without errors, the bitfile also works fine. but in the ngdbuild warnings, i get this -
ConstraintSystem - A target design object for the Locate constraint '<NET "datain_c" LOC = AL37>' could not be found and so the Locate constraint will be removed.
but in my pinout report, the datain pin is still defined at AL37 (so i guess the location constraint was still met).
I wanted to know if this warning is important  or if it can be ignored (because the pinout report still shows proper placement)
If I do want to get rid of this warning, what do i need to do?
thanks in advance ...
z.
is not the same as:
yes .. i know ... datain is not the same as datain_c ... so my question is why is this coming up as a ndg warning when i specify datain on loc AL37 ...  ?
thanks and regards,
zubin
Search your design files for datain_c it is probably there somewhere.
hi,
ive checked the ucf. i dont have a datain_c ... in the ucf file i just have datain defined in the design either. could it be that synplify is renaming the signal somehow?
Hi @zubin_kumar31
Yes that might be possible if this UCF file is being generated by Synplify tool.
Deepika.
Deepika.
hi,
the ucf i am using is a xilinx ucf only. lets call this design.ucf
i use design.ucf and convert it to sdc in synplify.
i synthesize the design using the design.sdc which generates the .edf file
then i take the .edf into xilinx ise and implement the design using design.ucf as the constraint file.
so is there some other constraint file that i should be using from synplify?
if so, why is my pinout report still OK after i implement the design (using design.ucf) in xilinx?
z.
