Not getting Ping at 1Gbps speed from TEMAC core using xilkernel
We are using Virtex-5 FX100T and using PPC in our application.In SDK,final application is built using xilinxkernel and lwip added.When application is running,and connected to a PC having a Gigabit Ethernet Adapter and with auto-negotiation settings,it is connected with 1Gbps speed but Ping is not working at 1Gbps link speed,it is showing destination host unreachable.When the adapter setting in PC Ethernet  is changed to 100 Mbps Full Duplex,and application is re-run it gets connected and ping is working fine.Is there any setting in the xilkernel and LWIP??
Re: Not getting Ping at 1Gbps speed from TEMAC core using xilkernel
lwip would have nothing with this. Are you sure your upstream switch/router has 1Gbps too?
