Open Source Soft Processor Development Kit Advice
We're looking for an open source soft processor development kit...
1.  Where we can modify the instruction set  and "re-flash" the core (not just extend the instruciton set but modify the existing instructions)
2.  Is being used in real commercial products and isn't just an open source academic product
3.  Is "beefy" enough to support desktop OS's such as Ubuntu with a GUI and network stack
4.  There are commercial workstations and servers which could run the same (but a modified) soft processor HDL.  (we want to be able to eventually sell the modified processor on real commercial hardware)
5.  There is a well supported development environment to reprogram the processor
I was looking at the UltraSPARC T1 and T2 processors as a solution but I didn't know if it OpenSPARC was growing or dying in the community.  I also don't know if OpenRISC has better solutions or if there are alternate solutions we havn't heard about.
Any advice on what you think the best solution for us is would be great.
v/r,
Bill
Re: Open Source Soft Processor Development Kit Advice
I thought I'd answer my own question if someone has the same question.
We ended up buying a Zedboard which has a Zynq 7000 SOC.
We are able to bootstrap RISC-V linux on the programmable logic with the Rocket Core soft processor.  Rocket core is open source and so we can modify the instructions as we wish.
b,
As no one has posted a reply, might I suggest using the Xilinx MicroBlaze which fufills all your needs except open source?
If MicroBlaze is used in our devices, you have the right to use it, modify it, etc.
My only experience is with the LEON soft core in the public domain, but I have no idea what OS it might support, and as will all open source, I am sure the tools are hard to find, and if found, hard to use (as bugs are unlikely to get fixed).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hey Austin,
Thanks for replying.
If MicroBlaze is not open source then how can we modify it?
Specifically we need to modify how the instructions themselves within the core.
Bill
There is an open source implementation of MB out there. I am not sure if it is GPL or LGPL and I am not sure if Xilinx would have any issues with using a reimplementation of MB (with some different instructions apparently) on a non-Xilinx device
I apologize,
The source code used to be available (for a fee) but is no longer,
As mentioned, there are open source versions of MiCroBlaze out there.
To support linux you need a machine with memory manager capability...
Austin Lesea
Principal Engineer
Xilinx San Jose
@kimballwb. This sounds interesting. Do you have this online somewhere to have a look?
