I am having a problem with SDK, it keep crashing. I am using CentOS 5.6 on an IBM workstation. Dual Intel Xeon 3.2G processors with HT and 3G of RAM.
When I check the /var/log/messages log, I can see the "killed process by kernel -- out of memory" message . But by checking the memory, I still have enough memory for the application.
The problem usually happens when I enable the debug terminal using terminal server commands in XMS. I am debugging dual MB system on the ML507 board. After enabling the terminal it works for some time then randomly stops .
I attached the interested part of the log file
