polyee13
Pin Placement of I2C / System Management Bus Clocks and Data lines
Do I2C/ SMBUS clock signals have to be routed to a GCLK pin of a Spartan-6 device? I'm running into some layout issues and a suggestion was made to move these clock and data signals from their current bank to another bank, which doesn't have any global clock pins.
gszakacs
Professor
Professor
@polyee13 wrote:
So with that said, it really shouldn't matter if the I2C clock lines are allocated to a Global clock pin. It's not like the I2C clock is a clock that will be distributed through the FPGA for the logic other than the I2C core.
Correct.
To add to that, you should know that unless you have an FPGA or CPLD with hysteresis on the
inputs (Schmitt triggers) you should not even consider using the SCL line as a clock.  Its rise
time is much too slow.
-- Gabor
-- Gabor
rcingham
If the I2C/SMbus slave block you are using treats the SCK pin as a clock (rather than oversampling it for rising and falling edges), then it is doing things the hard way!
polyee13
Not sure if I understand your reply. Let's assume that it treats the clock lines as a clock.
bassman59
Historian
Historian
You missed his point. You should use your FPGA's high-speed global clock to oversample the I2C signals and look for levels. Remember that I2C isn't edge sensitive.
rcingham
"Not sure if I understand your reply. Let's assume that it treats the clock lines as a clock."
Don't assume. Find out.
If you looked at the HDL for the I2C block, would you understand it?
polyee13
gszakacs
Professor
Professor
Correct.
-- Gabor
-- Gabor
bassman59
Historian
Historian
The I2C clock isn't used as a clock, full stop. It's a flag that, when high, indicates that the state of SDA is a valid logic level. When SCK is low, SDA can change, but SDA must be stable some setup time before the rise of SCK and cannot change until after SCK falls. So what is usually done is for the FPGA to oversample SCK, note when its rising edge occurs, and then wait a few (fast system) clock ticks before actually reading the value on SDA. You want to wait because, as noted, the rise time on SCK and SDA are not all that fast due to resistive pull-ups.
