Please reply me soon..
I have generated a BPSK signal and PPS(pulse per second) signal in virtex 6 FPGA and generated a bit file and tested the BPSK signal in the hardware.It's working fine.
By taking a copy of those files with port signals reorder and PPS(pulse per second) signal generation logic is changed.I generated bit file with this and tested the BPSK signal in hardware.But it is not giving the same results as before.I have created the same scenario for both cases.
Can you please let me know why this problem occur??
Thanks a lot...
Professor
Professor
Re: Please reply me soon..
Another common issue is timing.  If your design is not properly constrained, then any change can affect timing in a way that causes it to fail.
-- Gabor
hi,
as you said, you have reordered the ports. Have you changed the UCF file accordingly?
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Professor
Professor
-- Gabor
Can you elaborate your query with the actual changes you have done.
List out some scenario for better understanding.
Anusheel
Helpful answer -> Give Kudos
Thank you friend..
It's working fine..There was problem in the hardware...
Please close the thread by marking the relevant answer as accepted solution.
Anusheel
