Portmapping bidirectional ports
hi,
when it comes to connecting two bidirectional ports in Vhdl what can be done? does there exist some simple way such as
defining a bidirectional signal?
thanks guys,
    regards,
     bouvett
Re: Portmapping bidirectional ports
You don't need anything more than a standard signal declaration to connect two bi-directional ports.
Hopefully, you are doing this in a test bench and not attempting to do this within a single FPGA design.
i did try a standard signal declaration and it didn't work.
this is the problem: I am using a two directional port
(in and out). i am using this by sending data to it and receiving data
from it from another vhdl module also with a 2 directional port. Now
the problem is when it comes to connecting the module to the port;
when in the toplevel i start connecting all the modules together i
use:
fpga_pins <= module_pins
(where both fpga_pins and module_pins are bi directional)
the module can only send data, when i tell it to receive it does not work.
when i use:
 module_pins <= fpga_pins
the inverse applies.
when i use
it doesn't work, but i'm not sure whether it reads or writes...
with regards to your other point, no i didn't use a testbench, why?
thanks for the reply
just to make things clearer..
when i want to read, i set the module_pins as high impedance and then i read the port. but if the mapping is
fpga_pins <= module_pins; the read won't work.
if i write it vice versa though it will work.
so i think that the problem is possibly with the port mapping given that the port mapping  doesn't seem to take into consideration that the fpga and module pins are inout.
thanks again
Your original post and the subsequent reply posts are described two different topologies.
Based on your last post, my understanding is that you have a top level design with a bi-directional port and a sub-module that sources and receives the data from this port.
Your top level entity should desribe this port as an "INOUT" like the following example:
    my_bidir : INOUT std_logic;
Your sub-module should have three ports on it like the following example
    my_dout : OUT std_logic;
    my_dtri : OUT std_logic;
    my_din  : IN  std_logic;
In your top level a bi-directional IO buffer should be instanatiated like the following example:
    my_iobuf : IOBUF
          port map (
           IO => my_bidir,
           O  => my_dout,
           T  => my_dtri,
           I  => my_din
or this alternative behavioural example:
    my_bidir <= my_dout when my_dtri = '0' else 'Z';
    my_din   => my_bidir,  // On the sub-module port mapping
yes the system i am talking about is exactly what you said. i didn't really understand your reply though. my code looks like this. with regards to the submodule:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- THIS MODULE WILL IMPLEMENT THE BIDIRECTIONAL PORT NEEDED
-- SO THAT THE FPGA CAN READ AND WRITE TO THE GLCD FROM THE
-- SAME PINS.
entity GLCD_BI_DIRECTIONAL_PORT is
    Port ( GLCD_DATA_WRITE : in  STD_LOGIC_VECTOR (3 downto 0);
           GLCD_DATA_READ  : OUT  STD_LOGIC_VECTOR (3 downto 0);
           CONTROL : in  STD_LOGIC;
           GLCD_PINS : inout  STD_LOGIC_VECTOR (3 downto 0));
end GLCD_BI_DIRECTIONAL_PORT;
architecture Behavioral of GLCD_BI_DIRECTIONAL_PORT is
begin
PROCESS(CONTROL,GLCD_DATA_WRITE,GLCD_PINS)
BEGIN
IF(CONTROL = '0') THEN -- WRITE
GLCD_PINS <= GLCD_DATA_WRITE;
ELSE
GLCD_PINS <= "ZZZZ"; -- SET AS HIGH IMPEDANCE INPUT
GLCD_DATA_READ <= GLCD_PINS;
END IF;
END PROCESS;
end Behavioral;
The toplevel port is exactly as you mentioned ( GLCD_DATA : INOUT  STD_LOGIC_VECTOR (7 downto 0); )
So what exactly should i add/edit?
thanks a lot
Your code looks fine, except that you have the GLCD_DATA_READ line in the wrong place it is should be like this.
library IEEE;
-- SAME PINS.
           GLCD_DATA_READ  : out   STD_LOGIC_VECTOR (3 downto 0);
begin
PROCESS(CONTROL,GLCD_DATA_WRITE)
BEGIN
   ELSE
   END IF;
END PROCESS;
end Behavioral;
or in a shorter form
library IEEE;
-- SAME PINS.
begin
 GLCD_PINS      <= GLCD_DATA_WRITE when CONTROL = '0' else "ZZZZ";
end Behavioral;
hi,
i tried it again but it won't work at all. when i set
module_pins <= toplevel pins it works, but if vice versa it won't work... the problem is in the mapping i suppose....
by simply connecting the toplevel with the submodule using a simple std_logic signal is not working even though it seems good...
thanks for your help
Historian
Historian
@bouvett wrote:
hi,
Ed McGett's code is absolutely correct. If you are not implementing your design as he suggests, perhaps you should!
You provided your module code, but you didn't provide your top level code, but here is how it should look in snippets.
entity MY_TOP_LEVEL is
    Port ( ...             : ....
           TOP_GLCD_PINS   : inout STD_LOGIC_VECTOR (3 downto 0);
end MY_TOP_LEVEL;
architecture Behavioral of MY_TOP_LEVEL is
  component GLCD_BI_DIRECTIONAL_PORT
   end component;
begin
   my_bidir : GLCD_BI_DIRECTIONAL_PORT
       port map (
             GLCD_DATA_WRITE => ...,
             GLCD_DATA_READ  => ...,
             CONTROL         => ...,
             GLCD_PINS       => TOP_GCLD_PINS
Thanks for the reply, the problem was solved after i mapped the module directly to the pins without using any signals in between.
regards
Professor
Professor
You might have clarified this in the original post by showing how you connect
the sub-module to the FPGA pins.  There is no direct "assignment" operator
that works bidirectionally.  So in fact the top level port, if bidirectional or "INOUT"
MUST be directly connected to the submodule port with no intervening signal
or assignment.  The only other way is to break the bidirectional signal into
input, output, and output enable signals.  If you need to do that, the top level is
the best place to do it.  Note also that you cannot connect a bidirectional
signal to more than one sub-module.  i.e. no "T" connections.  This is because
there are no internal tristate drivers in the FPGA.  So again if you need to
branch out a bus inside the FPGA you should first make the signals all
unidirectional at the top level.
Gabor
-- Gabor
Visitor agouwin
I'm wondering do we have to declare the sub module this way? I ran into this problem and my port for the sub module would be like this
    Port ( CONTROL         : out    STD_LOGIC;
   end component;
I have to do this because all the GLCD_DATA_WRITE and GLCD_DATA_READ all handled inside my submodule which has nothing do to with other module. And I will have to leave them open anyway if I declare them.
so in the submodule declaration part, I would have two signals declared as
signal GLCD_DATA_WRITE : std_logic_vector(3 downto 0);
signal GLCD_DATA_READ  : std_logic_vector(3 downto 0);
and then I would have the following in behavior description
GLCD_PINS <= GLCD_DATA_WRITE when CONTROL = '1' else (others => 'Z');
Do you see this working? Thanks!!!
    Port ( ...             : ....
end MY_TOP_LEVEL;
   end component;
begin
       port map (
             CONTROL         => ...,
Teacher rcingham
"Do you see this working?"
No, because in VHDL up-to-and-including-VHDL-2002, you cannot read an output port in the associated architecture.
"If it don't work in simulation, it won't work on the board."
Professor
Professor
I've always seen this as an unnecessary restriction in VHDL.  Verilog does not have the same
restriction.  Generally the workaround is to use an internal signal like "CONTROL_i" for all
internal use and then assign the output like "CONTROL <= CONTROL_i" at the end of the code.
In Verilog you can use feedback from output ports, and even if these go to pins (for
example top level output ports) the feedback is internal, it does not actually require
an I/O buffer at the pin.  If necessary, XST will replicate registers to allow this feedback,
but it's all "under the hood" rather than explicit in your source code.  VHDL does have
the "buffer" port type which is essentially similar to the Verilog output port, in that it
allows feedback inside the module.  However I have read that this can cause other
problems, and is generally frowned upon for synthesis.
-- Gabor
-- Gabor
Teacher rcingham
"I've always seen this as an unnecessary restriction in VHDL."
...which is removed in VHDL-2008. When the XST parser supports that is a question that I would like to know the answer to!
Visitor agouwin
what about
signal CONTROL_i : std_logic;
CONTROL <= CONTROL_i;
GLCD_PINS <= GLCD_DATA_WRITE when CONTROL_i = '1' else (others => 'Z');
My main question is when the synthesizer will instantiate it to a tristate port?
agouwin,
You came in to the thread at the end of the discussion and it appears that you have missed some of the earlier key points.  I would suggest that you go back and re-read the first part of the thread, especially post 7.
