adrialex
Problem regarding portmaps
I have this code below and I can't determine why my output sum is incorrect. I'm just a beginner vhdl code programmer so I'm not quite sure about my coding. My component which is a carry look ahead adder is working fine. My only problem is that at the second instance of my component, i get a wrong output.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity adder is
    Port ( rst : in  STD_LOGIC;
           operandA : in  STD_LOGIC_VECTOR (7 downto 0);
           operandB : in  STD_LOGIC_VECTOR (7 downto 0);
           carry_in : in  STD_LOGIC;
           carry_out : out  STD_LOGIC;
           sum : out  STD_LOGIC_VECTOR (7 downto 0));
end adder;
architecture Behavioral of adder is
    SIGNAL count : STD_LOGIC_VECTOR(1 downto 0);
    SIGNAL temp : STD_LOGIC_VECTOR(3 downto 0);
    COMPONENT clahead_addr
    PORT(
        operandA : IN std_logic_vector(3 downto 0);
        operandB : IN std_logic_vector(3 downto 0);
        carry_in : IN std_logic;
        sum : OUT std_logic_vector(3 downto 0);
        carry_out : OUT std_logic
    END COMPONENT;
    --INPUTS
    SIGNAL oper_add1 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL oper_add2 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL oper_add3 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL oper_add4 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL carry_in_add : STD_LOGIC;
    --OUTPUTS
    SIGNAL sum_add1 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL sum_add2 : STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL carry_out_add1 : STD_LOGIC;
    SIGNAL carry_out_add2 : STD_LOGIC;
begin
    uut1: clahead_addr PORT MAP(
        operandA => oper_add1,
        operandB => oper_add2,
        carry_in => '0',
        sum => sum_add1,
        carry_out => carry_out_add1
    uut2: clahead_addr PORT MAP(
        operandA => oper_add3,
        operandB => oper_add4,
        carry_in => carry_out_add1,
        sum => sum_add2,
        carry_out => carry_out_add2
    process(rst,sum_add1,sum_add2,carry_out_add1,oper_add1,oper_add2)
    begin
        if rst = '1' then
            oper_add1 <= "0000"; oper_add2 <= "0000"; oper_add3 <= "0000"; oper_add4 <= "0000";
            sum <= "00000000";
            carry_out <= '0';
        else
                oper_add1 <= operandA(3 downto 0);
                oper_add2 <= operandB(3 downto 0);
                oper_add3 <= operandA(7 downto 4);
                oper_add4 <= operandB(7 downto 4);
                sum <= sum_add2 & sum_add1;
                carry_out <= carry_out_add2;
        end if;
    end process;
end Behavioral;
barryabrown
The dependency list of your process looks incorrect. This should work better:
process(rst,sum_add1,sum_add2,carry_out_add2,operandA.operandB)
Barry
barryabrown
Barry
adrialex
I would like to ask for a crash course about the sensitivity list of a process. What should and what shouldn't be included in it?
bassman59
Historian
Historian
Simple.
For a synchronous (clocked) process: the only things you put on the sensitivity list are the clock and an asynchronous reset (if you use one). That is it.
For a combinatorial process: anything that appears on the right-hand-side of any assignment in the process must be in the sensitivity list.
barryabrown
You can also avoid the sensitivity list by converting your combinatorial process to concurrent statements.  For example,
oper_add1 <= "0000" when rst = '1' else operandA(3 downto 0);
The above concurrent statement is equivalent to this process:
process (rst, operandA(3 downto 0))
begin
  if rst = '1' then
  else
  end if;
end process;
Barry
