kensou
Problem with cable on Xilinx 11.1
Hello everybody, I need help with a problem about Xilinx ISE 11.1.
When I finish compiling a projec, when I try via iMPACT to program my Spartan-3E device appears:
river windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
PROGRESS_END - End Operation.
Elapsed time =      2 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
When I link up the device appears "find new hardware" and after
" Installation of new driver Maybe you want to let Windows update look for the driver, or insert CD of automatic installation"
I also tried to install
I use windows XP via WMware Fusin on a MAC OSX SL on a MacBook Pro Latest Model.
 Drivers are missing??? I installed from ug344_windows.zip but nthing changed.
I use the simple USB PC cable as this one:
There's somebody who could be so kind to help me? I need to program this device for my last test of my university career....
Thanks a lot
Message Edited by kensou on 12-13-2009 01:37 PM
Message Edited by kensou on 12-13-2009 01:54 PM
kensou
Partially solved.
Now appears to me:
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000111000010001000001001001100
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000001010000001101000010010011
Anonymous
Not applicable
  • In most cases, this IDCODE error message is indicative of a board problem. Mostly problems related to JTAG chain hardware. So please check all the programming hardware of the board.
  • Perform an IDCODE looping test. If IDCODE looping fails, see http://www.xilinx.com/support/answers/8902.htm
  • Check all the connections as per configuration guide recommendations
  • Check the continuity of the cable & cable insertion direction.
  • Check all the voltages of device. They should be with the range  as per data sheet recommendations
iguo
http://www.xilinx.com/support/answers/13529.htm
http://www.xilinx.com/support/answers/20429.htm Slow down the Cable speed and try again.
beayeyz
I am using the same cable but ISE12.2 and having the same problem. How did u solve it?
thx
