rakeshm55
QuickBoot
 i was experimenting with quickboot(SPI mode) on AC701 referring to XAPP1081....
As I understand , when  update bitstream is modified the interface is in SPIX1 mode...Is it possible to work on SPIX4 mode??...does Xilinx provide support??....As of now I have limited the spi clk speed to 20MHz... can I switch to 66Mhz speed??
I have read in the forum issues with 32bit addressing, so until now i have experimented with bit compression enable.....Has it been rectified??....
One fundamental doubt when i execute the *.svf file how does the device know JTAG has to interact with SPI flash programmer??
