dzunior
RapidIO vs. PCI-E
Hi all,
I'm looking for a protocol to use for communication between separate FPGAs/board with FPGAs (with limited number of pins/serial high speed communication seems the best solution) and I wonder which one is better suited for this task. I've heard more about PCI-E so I assume there's more support for it also there are FPGAs with embedded PCI-E blocks, on the other hand RapidIO seems to be simpler and with lower overhead.
Can you recommend me one of them (or maybe some other protocol)?
Best regards,
Dominik
ddemmin
You might look at aurora as well.  It might be the simplest option.
http://www.xilinx.com/products/design_resources/conn_central/grouping/aurora.htm
The cores are available in coregen.
rcingham
Are all the FPGAs Xilinx?
Fibre or copper?
Streaming or packet?
What is your max byte/s?
"If it don't work in simulation, it won't work on the board."
dzunior
All FPGAs will be fro Xilinx (Virtex 6 probably), communication on copper (cable or PCI-E edge), packets ~1KB,  400-800 MB/s would be enough.
Dominik
ddemmin
rcingham
WIth those constraints, I second the suggestion of Aurora.
We are using it for inter-board communications at 3.125Gb/s.
dzunior
Yes, this one looks quite interesting.
Dominik
