Anonymous
Not applicable
Regarding clock pins and I/o pins
Hi Everyone,
  I am using Vivado 2014. For the design, is it to use BUFG or IBUF/OBUF primitives to the port pins or Tool will automatically takes thes buffers when PIN is assigned?
pulim
Tool will automatically inserts them
pulim
