cinnamon81
Resource utilization question
Dear all
Quick question about how to make a rough calculation as to the resource utilization of a design.
Basically, I'm looking at using a few of the available Xilinx IP cores. In their data sheets, they list resource utilisation for different devices. So to get a (rough) estimate for the total resources used, I simply add them together, correct?
Now, as far as I'm aware, a "slice" is simply a number of flip-flops and LUTs. But, according to the number of slices I calculate, my design is too big for my target fpga device. And yet, if I sum the flip-flops, I'm well under the max size for my target fpga. So which number is correct?
I don't yet have the development board or software (they are on the way), so I can't syntheisize this yet, but I need to get a rough idea of the resource utilization for my supervisor.
Cheers
C
gszakacs
Instructor
Instructor
LUTs and flip-flops are the basic resources of the FPGA, but they are always packed together
into slices containing some of each.  Depending on what you do with the LUT or flip-flop you may not
be able to use the other resource of the slice.  Usually the slice count is a good first-order indication
for fit because it represents the number of slices the design would use if no non-related logic
is packed into the same slice.  The FPGA can generally hold more logic than this, but when
you exceed this point and start to pack unrelated logic into the same slice, it becomes harder
to meet timing constraints.  You don't need the board to test out the capacity of your device,
just a copy of ISE tools.  If you build a simple project that contains the number of IP cores
you want and has at least a few inputs and outputs to prevent the cores from being optimised
away, you can see whether it will fit or not, and if it does, what sort of timing you might expect.
HTH,
Gabor
-- Gabor
gszakacs
Instructor
Instructor
HTH,
Gabor
-- Gabor
cinnamon81
Thanks, Gabor. That's a great help.
I wonder is there any "rule of thumb" for this kind of stuff?
For example, is it safe to say that if the total slice count (as per datasheets, rather than synthesis) is above the gate slice count, there's going to be trouble with timing, etc., that make the design infeasible?
gszakacs
Instructor
Instructor
Well, that's a sort of first-order rule-of-thumb.  In most cases you can do better than the 50% usage
implied by counting occupied slices rather than LUT's and flip-flops.  However there's more work
involved as the design approaches the capacity of the FPGA.  Meeting timing also depends on
how close you come to the FPGA's theoretical maximum performance.  If your design is slow
enough you may not have any problems regardless of placement.  For example suppose your
clock period is larger than a routing delay from corner to corner of the FPGA.   Then unrelated
packing may not cause timing problems at all.  This seems like an extreme case, but it can
happen when using very small but fast parts, like the smallest part in an FPGA family.  Utilizing
100% of the resources in the smallest parts may not be hard at all.  It's a much different story
at the other end of the size spectrum.
Gabor
-- Gabor
cinnamon81
Thanks again!
One final question on something I've never been quite sure about. What is the relationship between a logic cell and a slice/flip-flop/LUT. (I understand thata slice consists of 4 LUTs and 8 flip-flops inthe Spartan-6 architecture).
Cheers
C
