zhc
SDF file
I want to use Modelsim SE 10.0b to simulate a post-place&route model.
The post-place&route model is generated by ISE 13.1.
But I can't find the SDF file.
Could you tell me how to find the SDF file? Or there is another format file in 13.1.
rcingham
It might have a SDO suffix rather than SDF
"If it don't work in simulation, it won't work on the board."
evgenis1
Advisor
Advisor
It's usually placed under /<synthesis directory>/netgen/par/ , and has *.sdf extension.
Another option is to run netgen in timing simulation mode from command line to generate the sdf.
Evgeni
