Observer inftimer
SDK compiling error!
 Hi all!
 I have build a project with EDK ,and press "export hard design to SDK" , when I pressed "build all" in SDK ,compiler report a error ,the compling options include :... -MF "src/impro.d"   -MT "src/impro.d"  -o  "src/impro.o"   "../src/impro.c"
  then the error information :
../src/impro.c:in function 'impro_lock_Register':
../src/impro.c:error  'XPAR_IMPRO_ALL_HARD_RAM_PLBW_0_MEMMAP_REGLOCK' undeclared.
....many similar macro has no definition.
could you help me fixing the problem?thanks!
Re: SDK compiling error!
Can you check in the xparameters.h generated by BSP to check if this parameter exists?
--HS
Observer inftimer
thanks for your reply,,I opened the file "xparameter.h"  ,but  I  cannot find the macro definition .could you tell me why ?
Can you let me know how did you generate the driver? Also search for this parameter in the driver folder.
--HS
Observer inftimer
thanks a lot for reply again!
I am afraid that I cann't tell beacause this project is not created by me ,and I  am just responsible for some software coding ,BUT I find a phenomenon  may be helpful to solve the problem.:
under my main project folder ,there are many folders ,such as "__xps " folder ,"blockdiagram"folder ,"data"folder,"hdl"folder ,
"SDK"folder, "microblaze_0"folder,and so on.
the point is ,I find another "microblaze_0" folder in the ""SDK"folder/SDK_workspace_35/project_name_bsp/ ",when  I replace this microbaze_0  folder with the one which is under main project folder,  then the project detect that  the source file has been changed ,and ask me if  save the change,  I pressed yes,and the project  begin compling  automatically without error until the end ( the SDK project has been set as "build automatically") .   but if i pressed "build all" again when the  project has been complied . the error come  again !
Observer inftimer
thanks!
I have fixed the probem !
in fact !   there is no need to relace the whole folder (named microblaze_0)  ,only "xparameter.h"  needs replace .  then ,the error  disappear!
That's good news. The error as i mentioned was to check if your xparameters.h search for hte variable.
--HS
