04-07-2015 08:58 PM
I have been using the 10G-BASE R core(in 32 bit mode) for my communication from zc706 board to a custom board through optical cable. I had so far just been usign it by tweaking the top wrapper of the example design to use my ARM programmed Si5324 clock output to give a 312.5 MHz clock,.
I did not use any create_clocks command at my top level constraints ( directly routed clock pins to clock sources) and despite giving me critical warnings about a lower level clock contraint file missing on certain false paths, It used to give me a pretty consistent bitstream that used to give me correct error free communication.
I had added very basic logic to tie 3 of the 32 bits to SPI signals to be sent to the destination board. This was working at KHz frequencies but not at higher frequencies. So I tried playing around with clocking wizard, and entered constarints for top level clock, after which the Implementation no longer passes succesfully. I am having setup violations, in a few paths . To make sure its not the added logic ( though it has been tested), I removed the SPI signalling, and just sent basic data vector through the xgmii, but the timing and hence the implementation still fails(after adding top level clocks).
I need to know if it is a mandatory criteria for using create_clocks in the design even if I directly route the input port to a clock source.
04-07-2015 11:03 PM
04-08-2015 11:20 AM
It is an example design which comes with the core, and I am just modifying the top-level wrapper, assigning some GPIO LEDs,PINs to provide input/output control,using the system clock to do I2C programming of the jitter attenuator clock ( no added logic in the verilog level) ,which provides the required reference clock for the design. Do you think an example design will carry timing violations ?
When I compare the timing summary of the default example design with the tiing summary of my customized example design ,
I dont see the failing paths reported as passing in any of the clock groups defined in the example . In my design it is reported under the category **asynch_default**.
I have the below constraint in the IP timing constraint file which comes with the design, which is supposed to set these failing paths as false:
# False paths for async reset removal synchronizers
set_false_path -to [get_pins -of_objects [get_cells -hierarchical -filter {NAME =~ *sync1_r_reg*}] -filter {NAME =~ *PRE}]
Howver, the failing paths seem to be from above, ie they should ideally be trated as false paths by vivado, but the tool doesnt. Attaching a screenshot of the violations, and also what gets dumped on tcl console when I execute the get_pins from above. The last 8 lines show that these pins are supposed to be filtered out.
What are possible reasons this false path setting is not happening ?
