Anonymous
Not applicable
SmartHeap causing crashes for 64 bit Xilinx tools on Windows 8.1
I did a write-up of the problem here, with a workaround to disable SmartHeap:
http://escapehatchlabs.com/blog/fixing-64-bit-xilinx-apps-crashing-windows-8-1/
After disabling SmartHeap the Xilinx software runs great.
Thanks for giving your inputs. This will definitely help other users.
Thanks,Vijay
