States Machines vs. If Statements
Hey guys.
When I write a code, it's easier for me to think in a "state machine way" as oppose to if statements.
My question is, what is safer hardware wise?
When I work on Altera FPGAs, I like to keep the code as simple as I can, so the hardware wont mess it up. I don't like changing too many bits at one clock cycle, that's I'm asking this question.
Thanks a lot.
Assaf.
Instructor
Instructor
Re: States Machines vs. If Statements
For sequential logic, state machine code is easier to read and understand than deeply nested IF statements
If your code is limited to functions supported in the hardware, there is no inherent difference between the two coding styles which is more or less likely to result in "unsafe hardware".  Are you violating datasheet operating limits?  If so, that would indeed be "unsafe hardware".  Does your code describe asynchronous logic?  This, too, would generate "unsafe hardware".
If a synthesised design does not operate reliably or does not function as intended, it is almost certainly the designer's doing rather than a result of the hardware 'messing it up'.  This is generally true for both Xilinx FPGAs and non-Xilinx FPGAs.
Use a logic simulator to verify and debug logic function.
Use a timing analyser and timing constraints to verify signal timing.
If you travel from Tel Aviv to Haifa and you end up in Ashdod instead, do you fault the bus, the road, or the bus driver?
A proper Hardware Design or Verilog course instructor would be able to help you understand why this statement reflects fundamental misunderstanding.
-- Bob Elkind
SIGNATURE:
Summary:
