sslaj
Strange issue of adding ChipScope
Dear all,
I met a very strange issue when I was debugging with ChipScope.
I used ML605 board to control and communicate with a CMOS sensor via FMC HPC interface. My design was correctly simulated, but I was not successful to implement the design (Flag signals did not assert). Then I added ChipScope to debug, without any changing of code, my design has been successfully implemented. And all the signals are correctly displayed by ChipScope.
Furthermore,  in an other design, I can not read out the correct data from a dual port ram only except adding a ChipScope debugger.
It really confuse me. Does ChipScope affect the timing of signals or it optimize signals' route and place?
I am grateful for any help.
Cheers
ddemmin
Check your synthesis and map reports to make sure your logic is not getting optimized out. It sounds like part of your design is not connected correctly to an output and is getting optimized out.
ddemmin
Not likely but map could be falsely optimizing part of the design out. You could try enabling the "ignore keep hierarchy" in the map options.
markcurry
Does your design pass timing in both cases?  You are applying timing contraints, and checking them correct?
sslaj
Hi ddemmin,
Thanks for your reply. I tried enabling the "ignore keep hierarchy", but the problem still existed, and both case have no timing error. It is really strange, and I have never succeed without adding ChipScope.
Many thanks
sslaj
Hi Markcurry,
I am sure there are not timing constraint errors in both case. And I added the ChipScope without changing any properties. Any suggestions? I am using ISE 12.4 version
Cheers
markcurry
I'd still suspect timing.  What frequencies are you targeting?  What TIGs are in your ucf file?  Are you sure that all your constraints are correct?  Have you properly constrained all IOs for setup/hold times?
Where I've had problems such as yours - adding chipscope changing the behaviour - it's usually a problem with my constraints.  I've mistakenly applied constraints, or incorrectly created false paths.
My experience anyway.
Other things to consider with respect to missed timing:
http://www.xilinx.com/support/answers/42444.htm
ddemmin
As mark said.  List the clicks you are using, and what constraints you have associated with them.  Are all of your clocks on global or regional clock buffers?
sslaj
Hi markcurry,
Many thanks for your reply, it is really helpful.
I am very new to FPGA, and I can not understand timing constraints well.
For my application (ucf file), I just map the in/out port to the correct pin and only define the timing constraint of the Global clock signals. is this the main problem of the issue?
I attached my ucf file, and if you can have a quick look , I will be very grateful.
Cheers
sslaj
Hi ddemmin,
I attached my ucf file, and I checked the design, all clocks are on clock buffers.
Cheers
markcurry
You're contraining clocks in the UCF, that's good.  But not IO - that's bad.  Let's skip IO for now, (not a safe assumption at all but we've got to start somewhere.).  When you run trce, what do you get at the output?  It should say something like:
Timing summary:
Timing errors: 0  Score: 0  (Setup/Max: 0, Hold: 0)
What results do you see?  Any non-zero results?  I have a suspicion that you're not going to see all zeros here.  I could be wrong...
