Strange map report
Hi all, I recently tried to make simple n to 1 multiplexer with selection input. It just forward to output one part of input stdlogicvector, based on selection value. When I put selection 2 and width 10 as in code below, I get zero gate count in map report. When I put 2 and 32 I get value different than zero. Anybody has some idea? Cheers entity mltplx is generic( selection : integer:=2; width : integer:=10 ); port( input : in std_logic_vector((2**selection)*width-1 downto 0); sel : in std_logic_vector(selection-1 downto 0); output : out std_logic_vector(width-1 downto 0) ); end mltplx; architecture arch of mltplx is begin mux: process(input, sel) variable i : integer; begin i := conv_integer(unsigned(sel)); output <= input((i+1)*width-1 downto i*width); end process; end arch;
Hi lutteur,
  you shouldn't write the code like this.
  All the code you wrote will be turned to circuit.
  So, unlike software codes, you must imagine the circuit when you write HDL.
  I advice you use "CASE".
