TestBeanching User Logic
Hey.
I've created an IPIF, imported it to ISE, change it and now I try to test Bench it.
This is what I get
http://imageshack.us/photo/my-images/808/27648496.png/
Now, I can set the test bench my self, but is there any reason for this error I'm getting?
Thanks a lot.
Assaf.
Re: TestBeanching User Logic
Hey.
Do u mean this window?
http://imageshack.us/photo/my-images/12/33743353.png/
Anyway, I didn't give you all the information...
In the user logic there is the following sentences
library proc_common_v3_00_a;
use proc_common_v3_00_a.proc_common_pkg.all;
I open a new project with only the User_Logic.vhd file, added the Library manual and it worked.
Thank you very much.
you just got the bare testbench template without the automatic instantiation of your DUT, therefore there are still unresolved tags that are not intended to stay in the testbench, thus causing VHDL syntax errors.
When you create a testbench with the "New Source Wizard" a dialog box asks you for a module to be used in that testbench.
If none is chosen you might end up with this.
Just delete this bare template and repeat the "New Source Wizard".
Have a nice simulation
  Eilert
Hey.
