Tri-Mode Ethernet MAC V4.4 modelsim simulation problem
I've generated the Tri-Mode Ethernet MAC from xilinx core generator.
1. a Tri-Mode Ethernet MAC with (MAC speed = 10/100/1000Mbps) and run the example design with the provided demo_tb.
    everithing looks great and it s working just fine.
2.   a Tri-Mode Ethernet MAC with (MAC speed = 10/100Mbps) working with MII and run the example design with the provided demo_tb. and I see that data is transmited from Test bench to MII BUT I don't see any data coming out from the MAC (local_link) . looks like it doesn't work properly .
Can you please assist??
Many thanks
Yossi
What is the FPGA device?
Also refer  http://www.xilinx.com/ipcenter/ipevaluation/temac_evaluation.htm
the device is spartan3 dsp. x3sd3400a-5fg676
