Visitor roeldejong
UART Speed problems
Good morning,
I am busy realizing a communication between 2 FPGA boards ( For testing purpose we use the Spartan 3E Starter kits 2x ). I use 2x Profibus RS-485 tranceivers ( SN65HVD1176 ) ( 40 Mbps max )
These work perfect with the UART project i have at the moment.
The only problem i counter now is that above a bitrate of +- 600000 it will not receive correctly, On the scope the signal still looks ok to me. The frequency is also correct.
I attached the UART vhd file which i used, i also have a link with the uart project. UART link
In the project there is also the calculation to go from the default 50mhz frequecy of the board to go to a frequency to we can manage 115200 baud for example. I tested o many frequencies, this all works perfect except above 600k somewhere.
So my question is, does anyone know of wat to help me find why this doesnt work above that frequency ( for me ? ).
I can provide images of the signal on the scope, earliest tomorrow. I will post these in this topic.
ps. I Changed the loopback so it doesnt resend what it receives everytime. I just check if the receive character is an "N' for example and it notifies me when the received character is NOT a 'N'. From the other board i keep sending the N characters.
If i need to provide more information, just ask and i will post it.
Tags (3)
Instructor
Instructor
Re: UART Speed problems
Just looking at these two constants I can see one issue:
    constant c_tx_divider_val : integer := CLOCK_FREQUENCY / BAUD_RATE;
    constant c_rx_divider_val : integer := CLOCK_FREQUENCY / (BAUD_RATE * 16);
At 50 MHz, the rx divider will only be 5 (nominal 5.208333...) while the tx divider will
be 83 (nominal 83.333...).  5 times 16 is 80, so the difference is more than the 1%
normally required to maintain a good link (3.75%).  If you need to use high baud
rates and don't have a clock that is a neat binary multiple of the baud rate, the best
way is to build the receive baud divider into the receiver rather than using a fixed
oversampling rate of 16x.  For example in this case you could use the same divider
of 83 for both transmit and receive.  Then when you sample the input (at the 50 MHz
input clock frequency) you look for the falling edge that signals a start bit and at
that point reset the receive baud divider.  Then bit sampling occurs when the recieve baud
divider counter equals 83/2 (83 shifted right one) or 41.
Another way to do this is to use something like DDS to create a jittery 16x clock
at the exact required frequency (on average).
In any case you need to be sure that both tx and rx use the same divide numbers.
If you want to stick with the 16x rx sampling, then use a divide by 16 on the rx
clock for the transmitter rather than a separate divider.
-- Gabor
Instructor
Instructor
-- Gabor
Visitor roeldejong
Hello Gabor,
I stopped with the 16x oversampling now. I went to 5 ( Which is the minimal if im correct ? ). Already getting higher speeds after calculating good values which are within the 1% range.
It must have been the problem then the difference in the value was more then 1%.
I am going to test more with this now. Thank you for your clear answer.
//Roel
Visitor roeldejong
I still have another question about this, Now i changed to 5x oversampling.
I tried a baudrate of 1.000.000 whcih gives the following values.
50.000.000 / 1.000.000           = 50
50.000.000 / ( 1.000.000 * 5 ) = 10
Which looks to me no problem, since: 10 * 5 = 50
Now this gives the same problem as before, on the scope the signal looks ok. and a lower baudrate gives noproblem.
My maximum without a problem is now around 800kbaud.
Now the strangest thing.
I also used a value which i first used with 8x oversampling 781250 now with the 5x oversmpling.
50.000.000 / 781.250 = 64
50.000.000 / ( 781.250 * 5 ) = 12 ( 12,8 in the integer value )
So we have an error of 64-  ( 12*5 ) = 4. Where the maximum can be 1% = 0,64.
So the error is to big, but the communication works without any error.
Antough with 5x multisampling my maximum speed can be high then it was before with the 16x, which seems logical ?
Anyone can help me out on this.
//Roel
Instructor
Instructor
@roeldejong wrote:
Hello Gabor,
//Roel
Some older UART chips used an oversampling of 4x.  In an FPGA there is no real need to
follow this approach.  As I said in my earlier post, using the receive baud divider as the
sampling factor gives the best performance at higher baud rates unless your clock is
a neat multiple of the desired baud rate.
If you are controlling the baud at both ends of the link, the important thing is to be consistent
such that a transmitter's baud rate is within a small percentage of the receiver's baud
rate.  Your method of generating a separate rate for transmit and receive sections is
not well suited to this.  If you can set the baud for both ends of the link, and have the
same code running at both ends based on the same input clock frequency, then you
are better off using the 5x baud clock to run both transmitter and receiver.  If you are
communicating with another device that has standard set baud rates, then you need more
absolute accuracy and should consider the approaches I mentioned earlier.
The 1% factor I noted is commonly used because it should work if a transmitter is 1% high
and a receiver 1% low from the agreed standard rate.  Measuring a relative difference you
then can go to about 2% and still work.
There are other factors that can limit the tolerance to baud rate differences.  One is the
oversampling rate, which limits how close to the center of the start bit the sampling starts.
Remember that you are starting from near mid-bit, and any frequency difference will
walk the sampling point towards one end or the other of the bit interval.  In the case you
noted where the difference seemed too far to work, but the link worked, you may have had
the luck of starting from nearer to the edge of the bit time that the frequency walks you
away from.  In other words the error in center bit sampling was in the opposite direction
of the frequency error.
Another issue at high rates is the link physical transmission media.  For example many
RS422 transceivers have asymmetric propagation delay.  When the low to high prop
delay is very different from the high to low prop delay, the effective bit sampling window
gets smaller.  This means you need more accuracy in sampling than you would just
assume from the baud rate.
-- Gabor
