besa
UART module
I am using Virtex-5 XUPV5-LX110T and I want to display the results in the PC. I am trying to implement an UART module?
Does Xilix ISE 12.4 has an already done UART module?
As a communication standart I am thinking to use RS-232, or is better to use another?
eteam00
Instructor
Instructor
I am using Virtex-5 XUPV5-LX110T and I want to display the results in the PC. I am trying to implement an UART module? Does Xilinx ISE 12.4 has an already done UART module?
If you are using the EDK license, there is a UART Logicore included.  UART design is simple, and is often used as a 'homework assignment' design problem for first semester students.
Here is a useful link
And another useful link
As a communication standard I am thinking to use RS-232, or is better to use another?
RS-232 is an electrical interface (voltage levels, mostly) rather than a protocol definition.  The FPGA does not interface directly to RS-232 signals -- a buffer/translator on the board is required (and provided on the XUPV5 board).
Here is the Wiki article describing RS-232.
-- Bob Elkind
SIGNATURE:
Summary:
eilert
another simple UART core can be found in the Picoblaze ressources. (KCPSM3 in your case)
Have a nice synthesis
   Eilert
