Newbie zaglikosh
USB-JTAG
Hello.Does anybody know where can I download USB-JTAG drivers for zedboard(zynq-7000)? Thank you
Re: USB-JTAG
ZedBoard uses the same Digilent USB-JTAG module as ZC702. The driver is installed with ISE installation. If it doesn't work, try manually install the driver again from the executable in the directory below (replace 14.4 with your ISE version number).
C:\Xilinx\14.4\ISE_DS\ISE\bin\nt64\digilent
Cheers,
Jim
Re: USB-JTAG
USB JTAG driver is installed as USB Serial Converter. Is it OK?
Adept also recognizes two CPLDs.Adept
abdullah
Visitor annu_shah
Re: USB-JTAG
thank you so much i had the same issue n it was solved by going to this path C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\diligent,
