Unable to copy boot.bin and download image.ub file from /tftboot
I am using ububtu 12.10 and petalinux 2014_4
refering to manual of zedboard provided by you on youw website, I am trying to do all the lab session
Butin lab2 mI am not able to build coorect BOOT.bin file and Image.ub
I am using following commands
   1)  Copy the BOOT.BIN file from the pre-built directory to the SD card.
   2) Copy only the BOOT.BIN file from the ~/emblnx/labs/lab2/Avnet-Digilent-ZedBoard- 2014.2/pre-built/linux/images directory to the SD card.
After copying image and booting it on Zedboard ZC702
and runing following command on terminal window
 1)  U-Boot-PetaLinux> set serverip (host_ip_address)
2)  U-Boot-PetaLinux> run netboot
 logically thae above  command should download the image.ub file from /tftpboot on the host to the main memory of the ARM Cortex-A9 MPcore system and boot the system with the image. But I am getting an error "No PHY found" ping command is not responding.
