Use BRAM IN PL for load Application.elf in the case of DDR less system TE0722-01
I use a TE0-722-01 (and TE0722-02I) of TRENZ Electronic. This is a DDR less system actually. My design is finish but I can't Flash the module, because there is enough space for FSBL and Application. I'm familiar with the problem today, and one of the last solution I try to do is to create a BRAM in PL with control BRAM.
The goal is : (with a simple Design first, and simple application like Hello World and control LEDRGB on the module)
The FSBL is call first, so it's execute in OCM (192 KB actually ) , that load the bitstream (.bit), for configure the PL (FPGA), with my design. At the beginning of the FSBL a preload function is called for load my application.elf in BRAM in PL.
Then at the end of FSBL, a JUMP is doing for continue in the BRAM, then the OCM is free now.
At the Start of my application a function is call for move my application into the OCM and execute it. So it should work.
But actually I don't now how to do for load my application.elf into the BRAM, What are the addresses of my application, where it is, and how can I find this. So after that, how can I copy my application into OCM.
Actually my better sources is this example : http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Booting+and+Running+Without+External+Memory+Tech+Tip
but I have some difficult for adapt this.
Can you help me please? thank's a lot.
