Using xil_printf on admxrc2v3000
Hie,
I am trying to run c compiled code on microblaze containg Xil_printf statements.
I run that successfully on digilent board using uart as stdout ( intterface generated by edk).
But i am not able to run that on admxrc2 (alpha data board) as there is only a PCI interface available.
Even the board is not supported on edk.
Any suggestion would be great.
Do you have a JTAG inteface ? If yes you can use MDM to be used as a hyperterminal.
Please refer page 7 Processor STDIN/STDOUT of this Application Note.
http://www.xilinx.com/support/documentation/application_notes/xapp996.pdf
Thnx.
Hey nits11,
Were you able to solve your problem? If yes, please guide me how you did it.
I am facing the same problem with implementing a microblaze on alpha data cards actually.
Thanks,.
Anurag
