Observer jan.acosta
VHDL help
I am currently having trouble trying to implement a calculator that multiplies two 4-bit values.
The calculation is easy, but what I need to do is output the answer to 4 seven segment displays.
SInce there are about 255 possible answers when multiplying two 4-bit values, how do I write VHDL code without having to write each possble answer and assign a number to each of the seven segment displays?
Advisor joelby
Advisor
Re: VHDL help
Do you want to display the result in base 10? You should only need three displays.
You'll want to convert the number to BCD, which means that your three digit number is stored in three four-bit registers, representing 100s, 10s, and 1s.
Divide n by 100, put the modulo in the first register. Divide the remainder by 10, put the modulo in the second and the remainder in the third. Then you'll only need to define ten 7-segment outputs.
Figuring out how to do this will be a fun VHDL exercise! Alternatively, you could cheat and Google it.
Professor
Professor
Re: VHDL help
Another method may be to convert the 4-bit inputs to decimal and then implement a
decimal multiplier...
-- Gabor
Teacher rcingham
Re: VHDL help
I cheated and Googled for a synthesizeable binary-to-BCD converter and am very happy with it...
"If it don't work in simulation, it won't work on the board."
Instructor
Instructor
Re: VHDL help
joelby,
I think it is despicable that Gabor and rcingham are doing this fellow's homework assignment.  I am shocked... SHOCKED!
Otherwise I would have suggested using a 256x12 Block RAM for the multiply and BCD conversion.  But I won't, because I am above that sort of thing.
-- Bob Elkind
SIGNATURE:
Summary:
Observer jan.acosta
Re: VHDL help
Haha, I misread my homework assignment's requirements.
I am supposed to show the Hex value not the decimal value.
I figured that out already.  I have other problems now which I can't seem to figure out a way to trouble shoot.
Re: VHDL help
I need help for developing VHDL code for the solution of 3D Helmholtz wave equation using Green's function.I'm attatching the doc .
Tags (2)
Newbie zgd2449
Re: VHDL help
If any one can help me to solve this problem please
Develop a behavioral VHDL model of a synchronous (clocked) 2-digit, modulo-16 binary-coded-decimal (BCD) up counter. The counter should count from 0 up to 15 and then continue from 0 again. The counter should have an active high CLR signal to reset its contents to 0 at any time. The counter's state should be displayed on the 7-segment display module of the Nexys 2 Board. Both the CLK and the CLR signals should be mapped to pushbuttons, respectively. Note: when using signal CLOCK from a bush button for clocking your circuit you must add the statement NET "CLOCK" CLOCK_DEDICATED_ROUTE = FALSE; to your .ucf file. You should implement this counter using the FPGA, the 7-segment display and push-buttons on your Nexys 2 Board.
a) Turn in a hard copy of the .vhd and .ucf files for your design, respectively.
b) Map your circuit to the Xilinx FPGA chip that is located on your FPGA
Development Board by running the Implement step. Before doing so, add a User
Constraints (.ucf) file to your project to make proper pin assignments for your
designs. The Master .ucf file for the Nexys 2 Board is available through the Class
Web Page. However, you need to edit it to keep only those signals that are defined in
your .vhd file. Turn in only the device utilization and used pin assignments
sections, respectively, of the Pad Report.
Email : mass1311@yahoo.com
Historian
Historian
Re: VHDL help
Your professor has been notified of your attempt to cheat.
Expect a failing grade for this semester.
Re: VHDL help
Hmmm... For fun I did your assignment in about 1hr. Maybe you should drop the class, it's only going to get harder from here.
I like these books:
Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books
VHDL for Logic Synthesis, Andrew Rushton
FPGA Prototyping by VHDL Examples, Pong P Chu
