nju044
VHDL srl error
Hello, everyone:
I came across an error when  running XST synthesis. It said "srl can not have such operands in this context."
I refered to VHDL reference book but it didn't help, so I try to turn to you.
The line having the error is as follows:
slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7) srl 1;
Thanks in advance!
Best Regard.
Ninos K.
eilert
SRL & Co. are neither supported by the std_logic packages nor by numeric_std packages. They only work on boolean and bit types.
instead use this:
 slv_reg0(byte_index*8 to byte_index*8+7) <= '0' & Bus2IP_Data(byte_index*8  to byte_index*8+7-1); -- rightmost value is lost, leftmost value replaced by '0', all others shifted to the right.
Have a nice synthesis
  Eilert
eilert
instead use this:
  Eilert
nju044
Best Regard.
Ninos K.
