vsau
Vector array use in a buffer (as opposed to two dimensional array)?
I am curious on proper syntax for vector arrays?
I am trying to add a small memory buffer (stereo 16 samples 24bits per channel). On clk samples would go in and shift right in the buffer.
Suggestion on this thread: http://forums.xilinx.com/t5/General-Technical-Discussion/2-dimensional-array-problem-in-Verilog/td-p/42368 said not to use two dimensional arrays but use a one dimensional array of appropriate depth(24 in my case).
Unfortunately, I get the following error when attempting to compile:
ERROR:HDLCompilers:26 - "mem_buf.v" line 26 expecting ')', found '['
How do I correctly make the output buffer?
PS. I assume, shifting is also not correct
PSS this is on ISE Webpack 12.4
module mem_buf(
    input clk,
input reset, input [23:0] l_data, input [23:0] r_data,
Line 26 ---- output [15:0] r_buf[23:0],
output [15:0] l_buf[23:0] ); reg [15:0] r_bufreg[23:0]; reg [15:0] l_bufreg[23:0]; always @(posedge clk) if (reset) begin r_bufreg <=0; //FIXME need 16x24 bit zero ? l_bufreg <=0; end else begin r_bufreg <= {r_data, r_bufreg[15:1]}; //TODO is this correct? l_bufreg <= {l_data, l_bufreg[15:1]}; end assign r_buf = r_bufreg; assign l_buf = l_bufreg; endmodule
gszakacs
Professor
Professor
Verilog ports can be vectors, but not arrays.  So any range (and there can only be one range)
must come before the port name like:
  output reg [WIDTH-1:0] foobar,
You have a line:
which defines an array of vectors.  If you really need the port to transmit all
16 x 24 bits, then you need to write something like:
output reg [(16 * 24 - 1):0] l_buf
if internally you have an array, say l_buf_i, defined as:
reg [15:0] l_buf_i [23:0];
then you can use a loop like:
always @*
begin: named_process
  integer i;
  for (i = 0;i < 24;i = i + 1) l_buf[i*16 +: 16] = l_buf_i[i];
end
Note that the 16 and 24 in the above code example could be made into parameters
for a more general case.
HTH,
Gabor
-- Gabor
gszakacs
Professor
Professor
You have a line:
always @*
  integer i;
end
HTH,
Gabor
-- Gabor
vsau
Thank you for the quick reply!
I made the appropriate changes to my code per your suggestions.
Also, I decided not to output whole port width outside the module. I can do what I need to do inside the module and just output the result which is only (24 bits wide).
