Verilog to VHDL Translator
Is there any way to add Verilog source code files in Vivado or in any other tool which convert the Verilog code to VHDL ?
Scholar dpaul24
Re: Verilog to VHDL Translator
@joniengr081,
Mixed language sim is supported by most simulator tools. So why is this needed?
Best way to convert is manual convert.
FPGA enthusiast!
All PMs will be ignored
Voyager
Voyager
It might be easier to convert from VHDL to Verilog.  Have you tried vhdl2vl at all?
Scholar drjohnsmith
Verilog is a lot more 'fluid' than VHDL , which is strongly typed .
As such, the variability in verilog make sit very hard to auto convert to VHDL, where as , as pointed out , VHDL to Verilog is possible to auto convert.
Hi again,
Thanks for reply. Is it possible to write test bench in VHDL in Questa for a Verilog source code file ? In this way the behavior of Verilog source code will be known.
Scholar drjohnsmith
If your questa is multi language capable, then yes , that's quite normal.
