Virtex6+GTX wizard ....
hi,
i had a few questions regarding my understanding of the GTX wizard IP for virtex6 FPGA. basically i have my own PCIe controller core with a PIPE interface to the PHY. and I want to validate the controller, i dont have a PCIe PHY but i plan to use xilinx GTX IP core for for PHY. so my questions are -
1) we can generate the GTX wrapper in PCIe protocol template. will that give a "true" PIPE interface or some other "almost similar" interface?
2) in case the GTX wrapper (configured for PCIe) is not PIPE, then what type of interface is it? any doc where i can find this exact detail?
3) is my understanding correct that GTX wrapper to the V6 transcievers acts as a PHY (configured for PCIe)?
4) in theory, is my understanding correct that i can interface my pcie controller's PIPE interface to the GTX wrapper interface to get a total PCIe solution?
please let me know ...
thanks in advance ...
z.
1) we can generate the GTX wrapper in PCIe protocol template. will that give a "true" PIPE interface or some other "almost similar" interface? 2) in case the GTX wrapper (configured for PCIe) is not PIPE, then what type of interface is it? any doc where i can find this exact detail?
A: The similar GT wizard generated template for PCIE is used for the PCIE core of Xilinx and hence it should be a PIPE interface. You can create it and find out
A: Yes, it correct, the GTX wrapper is the PHY for the PCIe. That is what even our PCIE cores use.
A: Yes, we have customers who use similar solutions with their custom controller with GT PHY.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
Check the below link on a similar topic,which will answer your queries
http://forums.xilinx.com/t5/General-Technical-Discussion/PCIe-on-virtex6-using-high-speed-io-card-XAPP1022/td-p/550934
Satish
Anirudh
