Vivado Book..
https://www.amazon.com/Designing-Xilinx%C2%AE-FPGAs-Using-Vivado/dp/3319424378/ref=sr_1_1?ie=UTF8&qid=1540978728&sr=8-1&keywords=vivado
Hi, just wondering if anyone has read this book.. " designing Xilix FPGAS using vivado..  "  The amazon reveiws are mixed. but there is only two..
I'm wnating to get a good book to help me learn vivado. and FPGA's in general..
Re: Vivado Book..
Hi @mrpackethead
I did not read "designing Xilix FPGAS using vivado" book as per the reviews it is clear that more examples are not given in the book.
Always don't expect the direct examples from the documents or books, they are only for the reference purpose.
You can also refer the documents from the Xilinx Website.
https://www.xilinx.com/products/design-tools/vivado.html#documentation
Best Regards
Abhinay PS
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Re: Vivado Book..
@mrpackethead
Check out our courses:
https://xilinxprod-catalog.netexam.com/
https://www.xilinx.com/training/atp.html
--Syed
Re: Vivado Book..
I did look at the courses, and training but cou'dnt find anythign that really was a starting guide for how to use vivado.
Re: Vivado Book..
@mrpackethead
Check the following Quick take video, User guides and tutorial of Vivado which are from beginners.
Video:
https://www.xilinx.com/video/hardware/vivado-design-flows-overview.html
https://www.xilinx.com/video/hardware/getting-started-with-the-vivado-ide.html
User Guides:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug893-vivado-ide.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug892-vivado-design-flows-overview.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug910-vivado-getting-started.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug895-vivado-system-level-design-entry.pdf
Tutorial:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug888-vivado-design-flows-overview-tutorial.pdf
--Syed
Re: Vivado Book..
really am interested to hear from anyone that has looked at the book.
