i_am_b
Vivado bitstream generation error 2015.3
I'm using Vivado 2015.3 and zynq_TRD_2015.2. When I select "Generate Bitstream", I get the following errors:
[DRC 23-20] Rule violation (INBB-3) Black Box Instances - Cell 'zc702_base_trd_i' of type 'zc702_base_trd_i/zc702_base_trd' has undefined contents and is considered a black box.  The contents of this cell must be defined for opt_design to complete successfully.
[Vivado_Tcl 4-78] Error(s) found during DRC. Opt_design not run.
Can anyone please help with this?
Regrads,
B
pratham
@i_am_b TRD is built for 2015.2. You have to make changes in script for 2015.3. If you have 2015.2 give it a run it should work. If you dont let me know i will try to give working script for 2015.3
-Pratham
i_am_b
@pratham I don't have 2015.2 Version of Vivado. Can you please share the script which is compatible for 2015.3 ?
Bharath
pratham
@i_am_b I am facing some issues right now. Will send you script shortly
-Pratham
vibishna
I am also finding the same problem. Kindly share the script for changing the version!
vrde123
Kindly share the script with me also
deeksha@f7
You can use the tutorial of tcl command. try to generate in new version. It will upgrade the version of ip called.
If you dont know to generate.
Choose tcl commands one by one, run individually and understand the commands working. There is manual option to perform action corresponding to the tcl file.
