XC3S50AN soldering condition
Hello!
I have question about hand soldering condition for XC3S50AN-4TQG144C.
Is there wattage control condition for soldering iron in hand soldering condition?
If yes, could you let me know detail?
I checked the hand soldering conditions from "Implementation and Solder Reflow Guidelines for Pb-Free Packages".
My understanding for Hand Soldering conditions are following.
1) Temperature range : 350°C–375°C
2) Duration of up : 5 seconds
Teacher drjohnsmith
Re: XC3S50AN soldering condition
The wattage does not matter as such, its the temperature you need.
If its for home use, using leaded solder is slightly easier than lead free ( if you can get it )
Problems to lookout for,
the package moves as you solder it, A dab of glue under can help .
Solder whiskers between pins, ensure you have a good light and a microscope / magnifying glass to check.
The soldering iron loose heat to quick, a temperature controlled one is best,
Have a good supply of flux, and flux cleaner with a stiff brush.
Hi @mst_takahashi ,
I soldered many XC3S50AN-4TQG144C, I always used 350°C soldering iron and drag tecnique, you can see many video on youtube.
If you use good materials (soldering iron, flux and solder) you will have good results.
Good luck
Teacher drjohnsmith
Hi @auricm,
Thank you for your support.
Your soldering iron temperature information was useful to me.
And I refer to video on youtube.
Hi @drjohnsmith,
Thank you for your supprt.
I could understand that the wattage does not matter as such.
About problems to lookout for, Your advice was useful to me.
