Visitor jiwani
a noob qustion about pll
What will happen if I configure the PLL input clock to 100Mhz and the output to 200Mhz while actually the input clock is 50Mhz ?
Scholar watari
Re: a noob qustion about pll
Hi @jiwani
If you keep some constraints (loop filter setting, VCO frequency range, reference clock frequency range and so on), output frequency is 100MHz.
But, if you don't keep some constraints, PLL can not lock. So, output is still low.
Best regards,
Scholar watari
Hi @jiwani
Best regards,
Observer rembo
it means multiply by 2 will be enabled, and 100 MHz will be generated at the output.
Visitor jiwani
thx!
Visitor jiwani
thanks a lot!
