about the usage of resize function
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
use IEEE.numeric_std.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity project1 is
port(a:in STD_LOGIC_vector(23 downto 0);
     b:in STD_LOGIC_vector(23 downto 0);
     z:out STD_LOGIC_vector(24 downto 0));
end project1;
architecture Behavioral of project1 is
begin
 z<= (resize(a,25))+(resize(b,25));
end Behavioral;
The error i got is
ERROR:HDLParsers:808 - "D:/projects final/signextension/project1.vhd" Line 43. resize can not have such operands in this context.
Process "Check Syntax" failed
can you solve the problem in the code which i have mentioned above?
Re: about the usage of resize function
I'm taking a bit of guess that the problem lies with your use of libraries. You have named std_logic_arith, std_logic_signed and numeric_std. You shouldn't really mix them.
Just pick numeric_std (as it is the official library) and use that.
If you do, you will see (by reading the library functions for resize) that the input argument must be either signed or unsigned, not std_logic_vector.
You can either define your signals as signed/unsigned as appropriate or recast before resizing.
Howard
"That which we must learn to do, we learn by doing." - Aristotle
Historian
Historian
a) don't use std_logic_arith ever.
b) resize() is in the numeric_std package and works on unsigned and signed.
Can you correct the code which i have posted it to you?
Are you serious? Really, you couldn't do it yourself from the comments that have been made?
OK then, just this once, assuming you want to use signed vectors ...
library IEEE;
--library UNISIM;
entity project1 is
end project1;
  signal a_int, b_int : signed(23 downto 0);
  signal z_int        : signed(24 downto 0);
begin
 a_int <= signed(a);
 b_int <= signed(b);
 z_int <= (resize(a_int,25))+(resize(b_int,25));
 z     <= std_logic_vector(z_int);
end Behavioral;
