01-06-2010 02:07 AM
I have design synthesized at synplifypro. The edf file and port list file are then moved to the ISE as a black box to synthesized with other HDL design. My problem is the design of black box is optimized away by ISE and at the PnR only other IP is routed. When I have other IP commented and IO of the black box connected as the IO pad, I got only 25 track routed. It seems to me the ISE somehow interpret that the design of black box is useless and remove the whole design. How can I makesure the ISE will implement my design in black box?
thanks.
KK
01-06-2010 05:17 AM
Make sure that component is instantiated correctly and ports are mapped correctly.
Also be sure that ports mapped to the componenets are not left unconnected.
01-06-2010 09:28 AM
This is the port list of the black box:
module FPGA_PCIETop
PCIRST_tb2,
PCLK_IN,
TxData_Ln0,
TxDataK_Ln0,
RxPolarity_Ln0,
TxDetectRx,
TxElecIdle,
TxCompliance_Ln0,
PhyResetB,
PowerDown,
RxData_Ln0,
RxDataK_Ln0,
RxValid_Ln0,
PhyStatus,
RxElecIdle_Ln0,
RxStatus_Ln0,
pipe_rate,
pipe_txdeemph,
pipe_txmargin,
pipe_txswing,
PCLK_half_buf //Nathan 29sept 09
input PCIRST_tb2;
input PCLK_IN;
input PCLK_half_buf; //Nathan 29sept 09
output [15:0] TxData_Ln0;
output [1:0] TxDataK_Ln0;
output RxPolarity_Ln0;
output TxDetectRx;
output TxElecIdle;
output TxCompliance_Ln0;
output PhyResetB;
output [1:0] PowerDown;
input [15:0] RxData_Ln0;
input [1:0] RxDataK_Ln0;
input RxValid_Ln0;
input PhyStatus;
input RxElecIdle_Ln0;
input [2:0] RxStatus_Ln0;
//output PCLK_2X_bufg;
output pipe_rate;
output pipe_txdeemph;
output [2:0] pipe_txmargin;
output pipe_txswing;
endmodule
Below is the top level file, I have removed some IP instantiation to shorten the code to be shown here:
module KA_PCIETop(refclk_p, refclk_n, mperst, rxp, rxn, txp, txn, wake,
phystatus, powerdown, txdetectrx, txdata0, txdatak0, txelecidle, txcompl, rxpolarity, rxdata0, rxdatak0, rxvalid, rxelecidle, rxstatus0, rate, clk125, clk250);
input refclk_p;
input refclk_n;
input mperst;
input rxp;
input rxn;
inout txp;
inout txn;
output wake;
input [15:0] rxdata0;
input [1:0] rxdatak0;
input [2:0] rxstatus0;
input [0:0] rxvalid;
input [0:0] rxelecidle;
input phystatus;
output [1:0] powerdown;
output txdetectrx;
output [15:0] txdata0;
output [1:0] txdatak0;
output [0:0] txelecidle;
output [0:0] txcompl;
output [0:0] rxpolarity;
output rate;
input clk125;
input clk250;
wire clk;
wire clk125;
wire clk250;
reg rstn;
reg rstn_i;
wire rstn_srst_out;
reg [19:0] rstn_cnt;
wire [63:0] ZERO;
wire refclk_out;
reg [11:0] clk_10khz_cnt;
reg clk_10khz;
wire clkmux;
reg rate;
reg rate_r;
`ifdef TWO_FPGA
wire [15:0] rxdata0;
wire [1:0] rxdatak0;
wire [2:0] rxstatus0;
wire [0:0] rxvalid;
wire [0:0] rxelecidle;
wire phystatus;
reg [1:0] powerdown;
reg txdetectrx;
reg [15:0] txdata0;
reg [1:0] txdatak0;
reg [0:0] txelecidle;
reg [0:0] txcompl;
reg [0:0] rxpolarity;
`else
wire [0:0] rxvalid;
wire phystatus;
wire [1:0] powerdown;
wire txdetectrx;
wire [15:0] txdata0;
wire [1:0] txdatak0;
wire [0:0] txelecidle;
wire [0:0] txcompl;
wire [0:0] rxpolarity;
`endif //TWO_FPGA
`ifdef TWO_FPGA
wire [1:0] d_powerdown;
wire d_txdetectrx;
wire [15:0] d_txdata0;
wire [1:0] d_txdatak0;
wire [0:0] d_txelecidle;
wire [0:0] d_txcompl;
wire [0:0] d_rxpolarity;
wire d_rate;
reg [15:0] d_rxdata0;
reg [1:0] d_rxdatak0;
reg [0:0] d_rxvalid;
reg [0:0] d_rxelecidle;
reg [2:0] d_rxstatus0;
reg d_phystatus;
`endif //TWO_FPGA
// KA PCIE core
`ifdef TWO_FPGA
// pipeline pipe signal
always @(posedge clk or negedge rstn)
begin
if(!rstn)
begin
powerdown <='b0;
txdetectrx <='b0;
txdata0 <='b0;
txdatak0 <='b0;
txelecidle[0]<='b0;
txcompl[0] <='b0;
rxpolarity[0]<='b0;
rate <='b0;
d_rxdata0 <='b0;
d_rxdatak0 <='b0;
d_rxvalid[0] <='b0;
d_rxelecidle[0] <='b0;
d_rxstatus0 <='b0;
d_phystatus <='b0;
end
else
begin
powerdown <= d_powerdown;
txdetectrx <= d_txdetectrx;
txdata0 <= d_txdata0;
txdatak0 <= d_txdatak0;
txelecidle[0]<= d_txelecidle[0];
txcompl[0] <= d_txcompl[0];
rxpolarity[0]<= d_rxpolarity[0];
rate <= d_rate;
d_rxdata0 <= rxdata0;
d_rxdatak0 <= rxdatak0;
d_rxvalid[0] <= rxvalid[0];
d_rxelecidle[0] <= rxelecidle[0];
d_rxstatus0 <= rxstatus0;
d_phystatus <= phystatus;
end
end
`endif //TWO_FPGA
BUFGMUX mux_clk(
.O(clk),
.I0(clk125),
.I1(clk250),
.S(clkmux)
FPGA_PCIETop u_KABB //synthesis attribute box_type FPGA_PCIETop "black_box"
.PCIRST_tb2 (rstn),
.PCLK_IN (clk),
.TxData_Ln0 (d_txdata0),
.TxDataK_Ln0 (d_txdatak0),
.RxPolarity_Ln0 (d_rxpolarity[0]),
.TxDetectRx (d_txdetectrx),
.TxElecIdle (d_txelecidle[0]),
.TxCompliance_Ln0 (d_txcompl[0]),
.PhyResetB (),
.PowerDown (d_powerdown),
.RxData_Ln0 (d_rxdata0),
.RxDataK_Ln0 (d_rxdatak0),
.RxValid_Ln0 (d_rxvalid[0]),
.PhyStatus (d_phystatus),
.RxElecIdle_Ln0 (d_rxelecidle[0]),
.RxStatus_Ln0 (d_rxstatus0),
.pipe_rate (d_rate),
.pipe_txdeemph (),
.pipe_txmargin (),
.pipe_txswing (),
.PCLK_half_buf (clk_div2)
//other IP instantian is removed
endmodule
As I have mentioned in my last message, the black box IO is added as top level IO pad to ensure the ISE keep the design. But apparently it doesnt help.
Anyone has any idea whats go wrong?
KK
