I am using Xilinx Virtex 5 (XC5VLX110T)
FPGA to prototype a custom processor. As I have to go through several iterations to test different applications, I though I could use data2mem application to simply merge my application within the
FPGA bitstream. However, I encounter a couple of problems creating the bmm file.
My processor has 3 memories (one program memory and 2 data memories). In VHDL, I have the following code for each memory (just changed pmem by x or ymem):
constant size : integer := 18432;
constant g_data_width : integer := 32;
type pmem_core is array(0 to size - 1) of bit_vector(g_data_width - 1 downto 0);
impure function pmem_load (pmem_ext_load : in string) return pmem_core is
file pmem_file : text is in pmem_ext_load;
variable pmem_line : line;
variable pram_core : pmem_core;
begin
for I in pmem_core'range loop
readline (pmem_file, pmem_line);
read (pmem_line, pram_core(I));
end loop;
return pram_core;
end function;
signal pram_core : pmem_core := pmem_load("../memories/PMEM.txt");
signal wen_tmp : std_logic;
begin
wen_tmp <= '1';
process (clk)
begin
if clk'event and clk = '1' then
if (cs = '1') then
case wen_tmp is
when '0' => pram_core(conv_integer(a(11 downto 0))) <= to_bitvector(d);
when '1' => q <= to_stdlogicvector(pram_core(conv_integer(a(11 downto 0))));
when others => null;
end case;
end if;
end if;
end process;
I used the
FPGA Editor (ISE 11.1) after P&R to determine type and location for the BRAMs used. And then I constructed my bmm file, that looks like this:
ADDRESS_SPACE pmem RAMB36 [0x0000:0x47ff]
BUS_BLOCK
proc/i_pmem_wrapper/pram_core_pram_core_0_0/RAMB36_EXP [7:0] PLACED = X2Y8;
proc/i_pmem_wrapper/pram_core_pram_core_0_1/RAMB36_EXP [15:8] PLACED = X2Y7;
proc/i_pmem_wrapper/pram_core_pram_core_0_2/RAMB36_EXP [23:16] PLACED = X2Y6;
proc/i_pmem_wrapper/pram_core_pram_core_0_3/RAMB36_EXP [31:24] PLACED = X2Y5;
END_BUS_BLOCK;
END_ADDRESS_SPACE;
Executing data2mem with the following command, given the following error:
data2mem -bm proc.bmm -bt proc.bit -d > proc.txt
ERROR data2MEM:26 - Illegal bit lane width in ADDRESS_SPACE 'pmem'.
'proc/i_pmem_wrapper/pram_core_pram_core_0_0/RAMB36_EXP [7:0]' is 8 bits wide. Only 1, 2, 4, 9, 18, 36, 72 bit widths are allowed for this device.
I do not understand why I cannot use 8 bits wide, because in
FPGA Editor I can see that:
- pram_core_pram_core_0_0 pins: pmem_q(0) until pmem_q(7),
- pram_core_pram_core_0_1 pins: pmem_q(8) until pmem_q(15),
- pram_core_pram_core_0_2 pins: pmem_q(16) until pmem_q(23),
- pram_core_pram_core_0_3 pins: pmem_q(24) until pmem_q(32)
Can anyone tell me what is wrong with my bmm file? I really have no clue.
Thank you. Best,
Filipa
