Visitor flauber
cannot convert type universal_integer to type unsigned
I have a little, strange problem.
I am implementing a small state machine which is supposed to execute a program writen into a buffer via serial.
For this, I would like to use unsigned to make convertion between Integers and std_logic_vectors easy.
I am using
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
 only, yet it doe snot seem to work as expected.
I have a unsigned process counter PC to which I would like to add a 1.
So I write
PC:= PC + 1;
 I had read multiple articles which claim that this should work for unsigned values but I get an error:
 I have not he slightest clue what an universal_integer is supposed to be or how to cast it to an unsigend.
I tried
to_unsigned(1);
unsigned(1)
 But they both do not work.
Can someone explain to me what I am doing wrong? Isn't ieee.numerical_std.all supposed to enable this behaviour?
Here is the module (I am still a beginner so if you see somethign else, please tell me)
library IEEE;
library work;
use work.xadc_package.all;
entity command_state_maschine is
    generic(
        COMMAND_SPACE: Positive
    port(
        clk_in: in STD_LOGIC;
        rst_in: in STD_LOGIC;
        start_in: in STD_LOGIC;
        trigger_in: in STD_LOGIC;
        data_in: in command_space_type(0 to COMMAND_SPACE);
        finished_out: out STD_LOGIC;
        PULSES_out: out STD_LOGIC_VECTOR(0 to 7);
        SPI_CHANNELS_out: out SPI_VECTOR
end command_state_maschine;
architecture Behavioral of command_state_maschine is
    signal spi_start: STD_LOGIC_VECTOR(0 to 7);
    signal spi_data: STD_LOGIC_VECTOR(0 to 7);
    signal spi_finished: STD_LOGIC_VECTOR(0 to 7);
begin
    process
        variable PC: unsigned(15 downto 0);
        variable PROGRAM: command_space_type(0 to COMMAND_SPACE);
        variable REGS_16: r16;
        variable REGS_8: r8;
        variable i: natural;
        variable j: natural;
    begin
        if rising_edge(clk_in) then
            spi_start <= ('0','0','0','0','0','0','0','0');
            PULSES_out <= ('0','0','0','0','0','0','0','0');
            if rst_in = '1' then
                PC:= to_unsigned(2**PC'length -1, PC'length);
            elsif PC = to_unsigned(2**PC'length -1, PC'length) then
                if start_in = '1' then
                    PROGRAM:= data_in;
                    PC:= to_unsigned(0, PC'length);
                end if;
            else
                CASE PROGRAM(PC) IS
                    WHEN OP_STOP =>
                    WHEN OP_NOP =>
                        PC:= PC + 1;
                    WHEN OP_WAIT_SPI =>
                        if (REGS_8(PROGRAM(PC + 1)) xnor spi_finished) or REGS_8(PROGRAM(PC+2)) = (REGS_8'range => '1') then
                            PC:= PC + 2;
                        end if;
                    WHEN OP_WAIT_TRIGGER =>
                        if trigger_in = '1' then
                            PC:= PC + 1;
                        end if;
                    WHEN OP_SEND_SPI =>
                        i:= 0;
                        j:= 0;
                        for k in 0 to 7 loop
                            if REGS_8(PROGRAM(PC+1)) & REGS_8(PROGRAM(PC+2)) = '1' then
                                spi_data(j) <= REGS_16(PROGRAM(PC+3 + i));
                                i := i + 1;
                            end if;
                            j:= j +1;
                        end loop;
                        spi_start <= REGS_8(PROGRAM(PC+1)) & REGS_8(PROGRAM(PC+2));
                        PC:= PC + 3 + i;
                    WHEN OP_SEND_PULSE =>
                        PULSES_out <= REGS_8(PROGRAM(PC+1)) & REGS_8(PROGRAM(PC+2));
                        PC:= PC + 3;
                    WHEN OP_MOVE_CONST_8 =>
                        REGS_8(PROGRAM(PC+1)):= PROGRAM(PC+2) & PROGRAM(PC+3);
                        PC:= PC + 4;
                    WHEN OP_MOVE_CONST_16 =>
                        REGS_16(PROGRAM(PC+1)):= PROGRAM(PC+2) & PROGRAM(PC+3) & PROGRAM(PC+4) & PROGRAM(PC+5);
                        PC:= PC + 6;
                    WHEN OP_MOVE_8 =>
                        REGS_8(PROGRAM(PC+1)):= REGS_8(PROGRAM(PC+2));
                        PC:= PC + 3;
                    WHEN OP_MOVE_16 =>
                        REGS_16(PROGRAM(PC+1)):= REGS_16(PROGRAM(PC+2));
                        PC:= PC + 3;
                    WHEN OP_ADD_8 =>
                        REGS_8(PROGRAM(PC+1)):= REGS_8(PROGRAM(PC+1)) + REGS_8(PROGRAM(PC+2));
                        PC:= PC + 3;
                    WHEN OP_ADD_16 =>
                        REGS_16(PROGRAM(PC+1)):= REGS_16(PROGRAM(PC+1)) + REGS_16(PROGRAM(PC+2));
                        PC:= PC + 3;
                    WHEN OP_IF_8 =>
                        if REGS_8(PROGRAM(PC+1)) = REGS_8(PROGRAM(PC+2)) then
                            PC:= PROGRAM(PC+3) & PROGRAM(PC+4) & PROGRAM(PC+5) & PROGRAM(PC+6);
                        else
                            PC:= PC + 7;
                        end if;
                    WHEN OP_IF_16 =>
                        if REGS_16(PROGRAM(PC+1)) = REGS_16(PROGRAM(PC+2)) then
                        else
                            PC:= PC + 7;
                        end if;
                    WHEN OP_LSHIFT_8 =>
                        REGS_8(PROGRAM(PC+1)):= REGS_8(PROGRAM(PC+1)) rol 1;
                    WHEN OP_LSHIFT_16 =>
                        REGS_16(PROGRAM(PC+1)):= REGS_16(PROGRAM(PC+1)) rol 1;
                END CASE;
            end if;
        end if;
    end process;
    GEN_SPIS: for i in 0 to 7 generate
        SPIs: COMPONENT gated_spi
        GENERIC MAP(WIDTH=> 16)
        PORT MAP(
            clk_in => clk_in,
            rst_in => rst_in,
            start_in => spi_start(i),
            data_in => spi_data(i),
            finished_out => spi_finished(i),
            GATED_SPI_INTERFACE_OUT => SPI_CHANNELS_out(i)
    end generate GEN_CHANNELS;
end architecture;
 Thanks alot!
flambda
Re: cannot convert type universal_integer to type unsigned
I'm pulling this off the top of my head, so I can't guarantee this is correct but I think the problem is that your statement
PC := PC + 1;
 doesn't work because PC is an unsigned type, but the '1' isn't a unsigned type.  There's nothing telling the number how many bits to represent it with or if it's a signed or unsigned number.  Try the following wherever you add PC and a constant number:
PC := PC + to_unsigned(1, PC'length);
-Jordan
This signature intentionally left blank.
Visitor flauber
I tried to cast it already but it says that it cannot convert a universal_integer to an unsigned.
My guess is this is about a difference between an universal_integer and an integer but I cannot find any information
how they differ from each other.
Also, if you read this: http://www.mikrocontroller.net/articles/Rechnen_in_VHDL  (unfortunately in German),
adding an integer to an unsigend should work due to autocasts but assining a new value needs an manual conversion.
Also, if you look here: http://www.csee.umbc.edu/portal/help/VHDL/numeric_std.vhdl you can see function A.5
  -- Id: A.5
  function "+" (L: UNSIGNED; R: NATURAL) return UNSIGNED;
  -- Result subtype: UNSIGNED(L'LENGTH-1 downto 0).
  -- Result: Adds an UNSIGNED vector, L, with a non-negative INTEGER, R.
 Should a contant 1 not be seen as a non-negative integer? Why is it a "universal_integer" instead of an integer?
With best regards,
flauber
Historian
Historian
PC := PC + 1;
where PC is declared as unsigned and when using numeric_std, absolutely does work.
Your code has various other PC incrementers, such as PC := PC + 6; scattered about. Do ALL of them throw that warning, or just one in particular?
Historian
Historian
Also, why is PC declared and used as a variable? It should be a signal.
Visitor flauber
all of them throw the same error  message.
Why, btw, should PC be a signal? it is local to the process and only set by the process ergo should I not use a local variable instead of a global signal?
I also think i found my error.
i am using PC+1 as an index of an array. Therefore, the compiler is looking for a fucntion which has a signature like this:
unsigned, integer -> integer
 which does not exist, the functions are always defined to return a signed or unsigned, not an integer.
After I altered it to
to_integer(PC + 1)
 it worked as expected. Still, I find it very strage that I could not cast a 1 to an unsigned..
Also, is there a way to make this a bit nicer? Putting in 50 to_intger does not help the readability of my code, i am afraid.
Are unsigned not autocast to integers? I would have assumed this would happen (hm, but maybe this is not possible as the compiler could then cast PC to an integer and add 1, returning an integer instead of an unsigned.)
Historian
Historian
Well, one thing is the assignment semantics; you are obviously taking care to increment/update PC after each use, because if you updated it before you used it as your index or whatever you'd get the wrong value. This is VERY important and the use of a signal will ensure that you don't screw it up.
Signals aren't global; they only have entity scope.
Don't think that you need to have this concept of "global" vs "local."
to_integer(PC + 1)
The way to put it "nicer" would be to declare PC as a ranged integer. Instead of:
    signal PC : unsigned(15 downto 0);
just use:
    signal PC: natural range 0 to 65535;
After all, it's a counter, right? Just use an integer to count. Problem solved.
(For some reason, too many designers have this allergy to using integers.)
No, because unsigned is more akin to std_logic_vector than to integer. unsigned is a vector; integer is not, so you need a conversion function, not a typecast, to and from the vector.
