Observer thetford
checkpoint making bitgen fail
I am building a design in vivado 2014.2 that has my own custom core instantiated in a block diagram. When I build the design, synth and implementation work without errors. Then when I generate bitstream I get the following error:
The error doesn't make sense in that the signals it complains about are differential, i.e. driven by an OBUFDS in the code, and specified as a TMDS_33 in the XDC file. What is this checkpoint stuff and how do I make it go away? I suspect it is something embedded in the IP core from before I had the OBUFDS in the design, but I have no clue how to delete it. I've deleted all the runs, rebuilt stuff, repackaged the IP, but this error remains. Any idea how to make this bogus error go away?
-Jeff
Re: checkpoint making bitgen fail
Can you show us how these ports are connected in synthesized and implemented designs?
I suspect that obufds might have got trimmed for some reason and the tool assumes them as single ended.
Did you connect obufds inputs and outputs properly?
Deepika.
Deepika.
This kind of DRC error might occur when you are declaring pins in an XDC file, but with no actual design behind it driving these pins.
