clock issue in zynq custom ip
I am using zynq zc702 and I have designed couple of custom ip which are written in verilog module and would reside in PL section, now my design is working fine and the ps and pl communicatioo means i.e. arm with custom ip is done..but in my verilog design there is clk input and I need to measure ,the time required for executing my verilog module, from simulation, I know how many clk cycle has been elapsed ,so it would be easire to find out .
but what is the frequncy of PL section..? is it FCLK_CLK0? now in my custom ip, i had to use Bus2IP_Clk as clk input to my verilog design..so is this same as clock frequncy of my zynq board?
regards
Re: clock issue in zynq custom ip
Joy,
Your custom IP has port called S_AXI_ACLK now this same as IP2BUS_clk..now check the .mhs in XPS, if you find that in FCLK_CLK0 is port mapped to S_AXI_ACLK ( this  usually happens)..Then FCLK_CLK0 is the clock source to your IP. In XPS from Zynq tab,,click on clock generation, you would find the frequncy of FCLK_CLK0..usually 50Mhz...
I would prefer to use vivado and IPI for this designs..as this port connections seems to be much clear there..
thanks
Scholar austin
table 25-1, ug585
The AXI bus clock may be selected to be some number of values.
100 MHz is a selection, as are 133, and 200 MHz.
So, the clock you choose and the settings, will provide you with what is happening...
Table 25-2 lists all the available peripheral clock rates as a multiple  of the system clock for the CPU's.
25-3 lists examples.
25-10 lists the clcoks you requested.
Austin Lesea
Principal Engineer
Xilinx San Jose
Joy,
thanks
how to give Clock in zynq custom ip PL section
HEY
I am inspired from your topic , i Have a similar but different problem , I Have design a parameterised counter using ip pakager now i make a new system where i called that Ip , now user changed parameter i.e. counter width .
now since i made output as external but how to give clock and reset and standalone run that for behavioural simulation
so any solution to that , secondly do i need to use PS section to drive clock for my IP
or A test bench is sufficient to run the behavioural simulation
secondly can i generate a bit file and test that design on Zedboard , then how to write the ucf/xdc file.
please help me , i am working to resolve such from lasr 120 hours
can you give your design PDF so we can do such exercise
we will be grateful to you
Teacher eteam00
duplicate posts
gaurav,
Please do not post multiple copies of your request in multiple threads.  And please do not pose a new question or problem in a thread which has already been marked as 'solved'.
Please keep discussion of your issue in the thread you have already created.
-- Bob Elkind
SIGNATURE:
Summary:
Re: duplicate posts
Sorry , I will take care of the this in future and decorum of forum
