maharjanmilan
conversion from binary to integer and vice versa
Hi !
      Is it possible to convert the input data in binary form (std_logic_vector) to integer in VHDL?  The converted  integer data is used to perform some fixed point calculations using AccelDSP from xilinx. Once the calculations are made,the output generated from the AccelDSP is integer and my second question is, is it possible to convert back the result into std_logic_vector again?
Milan
matthias.meurer
to convert std_logic_vector to integer use conv_integer(std_logic_vector_signal).
To convert integer to std_logic_vector use conv_std_logic_vector(integer_signal, num_bits).
num_bits are the number of bits the resulting std_logic_vector signal will have.
for example:
signal sig1 : std_logic_vector(15 downto 0):=X"0123";
signal sig2 : integer range 0 to 65535:=0;
signal sig3 : integer range 0 to 65535:=456;
signal sig4 : std_logic_vector(15 downto 0):=X"0000";
    --To convert sig1-->sig2
sig2<=conv_integer(sig1);
    --To convert sig3-->sig4
sig4<=conv_std_logic_vector(sig3,16);
regards,
Matthias
bassman59
Historian
Historian
matthias.meurer wrote:
for example:
regards,
Matthias
Please do not recommend std_logic_arith. It's broken, it's deprecated, and it's been replaced by numeric_std.
bassman59
Historian
Historian
maharjanmilan wrote:
Hi !
Milan
Look up the functions in the numeric_std library. See Ashenden's book for some good help.
Your conversion functions depend on whether the binary value represents a signed or an unsigned number. The numeric_std library adds proper signed and unsigned types.
So, for example, at the top of your source, add:
use numeric_std.all;
.... at the declarative part of the architecture (between the architecture keyword and the begin):
    signal foo_slv : std_logic_vector(15 downto 0); -- a 16-bit binary vector
    signal foo_us : unsigned(15 downto 0);          -- a 16-bit unsigned vector
    signal foo_int : natural range 0 to 65535;      -- a 16-bit natural (non-negative integer)
and in the main body of the architecture:
    -- going from SLV to integer:
    foo_slv <= X"ABCD";
    foo_us  <= unsigned(foo_slv);    -- this is a typecast
    foo_int <= to_integer(foo_us);   -- overloaded function
    -- going from integer to SLV:
    foo_int <= 12345;
    foo_slv <= std_logic_vector(to_unsigned(foo_int, foo_slv'length));
-a
drjohnsmith
this is a few pages on a site I regularly print out for people wiht these sort of questions,
http://www.synthworks.com/papers/vhdl_math_tricks_mapld_2003.pdf
might be of future help
jamesona
Hi what about signed?
bassman59
Historian
Historian
What about it?
