Visitor sunbelt57
converting verilog to vhdl
I have a sample project which came with my Waveshare board to decode a 4x4 keypad. The top file is a schematic and there are 2 vhdl files and 1 verilog file. I'm converting the verilog file (key44.v) to my own vhdl (key44.vhd). I have 2 test benches set up for each. Here's the verilog file:
// Module declaration
module key44
	code      ,
	col       ,
	valid     ,
	row       ,
	sys_clk   ,
	rst
// Port declaration
output  [3:0]  col     ;
output         valid   ;
output  [3:0]  code    ;
input   [3:0]  row     ;
input          sys_clk,rst ;
reg     [3:0]  col,code;
reg     [5:0]  state,next_state;
parameter  S_0 = 6'b000001,
           S_1 = 6'b000010,
           S_2 = 6'b000100,
           S_3 = 6'b001000,
           S_4 = 6'b010000,
           S_5 = 6'b100000;
reg        S_row ;
reg [3:0] count,row_reg,col_reg;
reg       clk2,clk4;
reg [4:0] Mega_cnt;
wire      clk;
always @( posedge sys_clk, negedge rst )
begin
	if(!rst)	Mega_cnt<=0;
	else		Mega_cnt<=Mega_cnt+1;
end
assign clk = Mega_cnt[4];
// Frequency Division Two
always @( posedge clk )
clk2 <= ~clk2;
// A quarter of the clk
always @( posedge clk2 )
clk4 <= ~clk4;
// Check the Key
always @( posedge clk4, negedge rst )
if(!rst)
	begin
		count <= 0;
		S_row <= 0;
	end
else
	begin
		if(!(row[0]&row[1]&row[2]&row[3]))
			begin
				if(count < 'd4)
					count <= count + 1;		// Filter
				else
					S_row <= 1;
			end
	//	else if(state[5]||state[0])
		else if((state == S_0) || (state == S_5))
			begin
				count <= 0;
				S_row <= 0;
			end
	end
assign valid = ((state == S_1)||(state == S_2)||(state == S_3)||(state == S_4)) &&  (!(row[3]&row[2]&row[1]&row[0]));
// Save the value of row and col
always @( negedge clk )
if( valid )
	begin
		row_reg <= row ;
		col_reg <= col ;
	end
else
	begin
		row_reg <= row_reg ;
		col_reg <= col_reg ;
	end*/
// Decode the Key
always @( row_reg, col_reg, clk )
	case( {row_reg,col_reg} )
		8'B1110_1110: code = 4'hd;
		8'B1110_1101: code = 4'h9;
		8'B1110_1011: code = 4'h5;
		8'B1110_0111: code = 4'h1;
		8'B1101_1110: code = 4'he;
		8'B1101_1101: code = 4'ha;
		8'B1101_1011: code = 4'h6;
		8'B1101_0111: code = 4'h2;
		8'B1011_1110: code = 4'hf;
		8'B1011_1101: code = 4'hb;
		8'B1011_1011: code = 4'h7;
		8'B1011_0111: code = 4'h3;
		8'B0111_1110: code = 4'h0;
		8'B0111_1101: code = 4'hc;
		8'B0111_1011: code = 4'h8;
		8'B0111_0111: code = 4'h4;
		default		: code = 4'h0;
	endcase
// State Machine : Mealy
	if( !rst )
		state <= S_0 ;
	else
		state <= next_state ;
always @( state, row, S_row )
begin
	col = 0;
	case( state )
	S_0 :  begin
			col = 4'b0000;
			if(S_row)	next_state = S_1;
			else		next_state = S_0;
		end
	// Decoding...
	S_1 :  begin
			col = 4'b1110;
			if(row!='hf)	next_state = S_5;
			else			next_state = S_2;
		end
	S_2 :  begin
			col = 4'b1101;
			else			next_state = S_3;
		end
	S_3 :  begin
			col = 4'b1011;
			else			next_state = S_4;
		end
	S_4 :  begin
			col = 4'b0111;
		end
	S_5 :  begin
			col = 4'b0000;
			if(row == 4'b1111) 	next_state = S_0;
			else 				next_state = S_5;
		end
	default: next_state = S_0;
	endcase
end
endmodule
and here's my vhdl version:
-- key44a.vhd - converted from key44.v (verilog)
library ieee;
USE IEEE.std_logic_1164.ALL;
use ieee.numeric_std.all;
entity key44 is
	port (reset: in std_logic;
		row: in  std_logic_vector(3 downto 0);
		col: out  std_logic_vector(3 downto 0);
		sys_clk: in std_logic;	-- this in NOT the 50MHz clock!
--		valid: out  std_logic;
		code: out std_logic_vector(3 downto 0));
end key44;
architecture key_arch of key44 is
-- signal & constants
	constant DEC: integer:= 5;
	constant MEGA_VAL: integer:= 7;
	type state_type is (S_0,S_1,S_2,S_3,S_4,S_5);
	signal state_reg, state_next: state_type;
	signal S_row: std_logic;
	signal count: unsigned(3 downto 0);
	signal row_reg, t_col, col_reg: std_logic_vector(3 downto 0);
	signal clk1, clk2, clk4: std_logic;
	signal Mega_cnt: unsigned(MEGA_VAL-1 downto 0);
	signal t_valid: std_logic;
	signal test: std_logic;
	signal test2: std_logic;
	signal test3: std_logic;
	signal temp: unsigned(7 downto 0);
	signal b_valid: boolean;
begin
	process(reset,sys_clk)
	begin
		if reset = '0' then
			Mega_cnt <= (others=>'0');
			clk1 <= '0';
		elsif sys_clk'event and sys_clk = '1' then
			Mega_cnt <= Mega_cnt + 1;
			clk1 <= Mega_cnt(MEGA_VAL-DEC);
		end if;
	end process;
	process(clk1,reset)
	begin
		if reset = '0' then
			clk2 <= '0';
		elsif clk1'event and clk1 = '1' then
			clk2 <= not clk2;
		end if;
	end process;
	process(clk2,reset)
	begin
		if reset = '0' then
			clk4 <= '0';
		elsif clk2'event and clk2 = '1' then
			clk4 <= not clk4;
		end if;
	end process;
--	b_valid := ((state_reg = S_1 or state_reg = S_2 or state_reg = S_2 or state_reg = S_2 or state_reg = S_2) or (not(row(3) and row(2) and row(1) and row(0)))) ;
	process(clk1,reset,state_reg,row)
	begin
		if reset = '0' then
			t_valid <= '0';
		elsif clk1'event and clk1 = '0' then
			if (state_reg = S_1 or state_reg = S_2 or state_reg = S_3 or state_reg = S_4) and
					 (row(0) = '0' or row(1) = '0' or row(2) = '0' or row(3) = '0') then
				t_valid <= '1';
			else
				t_valid <= '0';
			end if;
		end if;
	end process;
	begin
		if reset = '0' then
			test <= '0';
			if (state_reg = S_1 or state_reg = S_2 or state_reg = S_3 or state_reg = S_4) then
				test <= '1';
			else
				test <= '0';
			end if;
		end if;
	end process;
	begin
		if reset = '0' then
			test2 <= '0';
			if (row(0) = '0' or row(1) = '0' or row(2) = '0' or row(3) = '0') then
				test2 <= '1';
			else
				test2 <= '0';
			end if;
		end if;
	end process;
--	process(state_reg,row)
--	begin
--		if (state_reg = S_1 or state_reg = S_2 or state_reg = S_3 or state_reg = S_4) and
--				 (row(0) = '0' or row(1) = '0' or row(2) = '0' or row(3) = '0') then
--			t_valid <= '1';
--		else
--			t_valid <= '0';
--		end if;
--	end process;
-- check the key
	process(clk4, reset,row)
	variable temp1: boolean:= FALSE;
	begin
		if reset='0' then
			count <= (others=>'0');
			S_row <= '0';
			test3 <= '0';
			temp1:= FALSE;
		elsif clk4'event and clk4 = '1' then
			temp1 := (row(0) = '0' or row(1) = '0' or row(2) = '0' or row(3) = '0');
			if temp1 = TRUE then
				test3 <= '1';
				if count < 4 then
					count <= count + 1;
				else
					S_row <= '1';
				end if;
			elsif (state_reg = S_0 or state_reg = S_5) then
				test3 <= '0';
				S_row <= '0';
--				temp:= FALSE;
			end if;
		end if;
	end process;
-- save the value of row and col
	process(t_valid,row,t_col,reset,clk1)
	begin
		if reset = '0' then
			row_reg <= (others=>'0');
			col_reg <= (others=>'0');
--			t_col <= (others=>'0');
			if t_valid = '1' then
				row_reg <= row;
				col_reg <= t_col;
			end if;
		end if;
	end process;
	col <= col_reg;
-- decode the key
	process(row_reg, col_reg, clk1)
	begin
			temp <= unsigned(row_reg & col_reg);
			case temp is
				when "11101110" => code <= "1101";
				when "11101101" => code <= "1001";
				when "11101011" => code <= "0101";
				when "11100111" => code <= "0001";
				when "11011110" => code <= "1110";
				when "11011101" => code <= "1010";
				when "11011011" => code <= "0110";
				when "11010111" => code <= "0010";
				when "10111110" => code <= "1111";
				when "10111101" => code <= "1011";
				when "10111011" => code <= "0111";
				when "10110111" => code <= "0011";
				when "01111110" => code <= "0000";
				when "01111101" => code <= "1100";
				when "01111011" => code <= "1000";
				when "01110111" => code <= "0100";
				when others => code <= "0000";
			end case;
		end if;
	end process;
-- state machine : Mealy
-- make this a one-process FSM to avoid t_col causing mult input error
--	process(reset,clk4, state_reg, state_next)
--	begin
--		if reset = '0' then
--			state_reg <= S_0;
--		elsif clk4'event and clk4 = '1' then
--			state_reg <= state_next;
--		end if;
--	end process;
	process(clk4, reset, state_reg,S_row,t_col,row)
	begin
		if reset = '0' then
			state_reg <= S_0;
			state_next <= S_0;
			case state_reg is
				when S_0 =>
					t_col <= "0000";
					if S_row = '1' then
						state_next <= S_1;
					else
						state_next <= S_0;
					end if;
				when S_1 =>
					t_col <= "1110";
					if row /= "1111" then
						state_next <= S_5;
					else
						state_next <= S_2;
					end if;
				when S_2 =>
					t_col <= "1101";
						state_next <= S_5;
					else
						state_next <= S_3;
					end if;
				when S_3 =>
					t_col <= "1011";
						state_next <= S_5;
					else
						state_next <= S_4;
					end if;
				when S_4 =>
					t_col <= "0111";
						state_next <= S_5;
					else
						state_next <= S_0;
					end if;
				when S_5 =>
					t_col <= "0000";
						state_next <= S_5;
					else
						state_next <= S_0;
					end if;
				when others =>
					state_next <= S_0;
			end case;
		end if;
	end process;
end key_arch;
The testbench for the verilog is attached as keypad_verilog and the one for vhdl is keypad_vhdl.
The part I'm stumped on is why does S_row start earlier in the vhdl version. Also, I'm not getting a valid signal.
The valid signal in the verilog version is:
The only equivalent I could come up with for vhdl is:
	begin
		if reset = '0' then
			t_valid <= '0';
				t_valid <= '1';
			else
				t_valid <= '0';
			end if;
		end if;
	end process;
I know this is a lot to ask but I thought someone could suggest something or see something I'm missing. I have the whole project setup at: github
Visitor sunbelt57
Re: converting verilog to vhdl
The previous jpg was the simulation for the vhdl. Here's the one for the verilog:
Visitor sunbelt57
The incoming clock (clk1) comes from a freq divider. clk2 is clk1/2 and clk4 is clk2/2. The test bench for each stimulates in row(3:0) like this:
row_proc: process
	begin
		row <= "1111";
		wait for 199 us;
		for i in 0 to 20 loop
			row <= "1110"; wait for 1 ms;
			row <= "1111"; wait for 3 ms;
			row <= "1101"; wait for 1 ms;
			row <= "1011"; wait for 1 ms;
			row <= "0111"; wait for 1 ms;
		end loop;
	end process;
Tags (3)
Visitor sunbelt57
Another thing I'm puzzled about is why the next_state in key44.v go from 1,2,32,4,8,16,1 while the state goes from 1,2,4,8,16,1.
I converted the state machine to a one-process because of t_col multiple inputs.
And I hade to col in the FSM with t_col because it wouldn't let me read from an output in the process that sets the row_reg and col_reg. Evidently, you can do that with verilog.
Visitor sunbelt57
[edit:] And I had to replace col in the FSM with t_col...
Visitor sunbelt57
I made a change to the test bench: I added more time for the rows to be non-FF
Visitor sunbelt57
I think what I'm not seeing is that the hardware will only return on non-FF row when the col scan matches up with the row from the keypad. I just can't stimulate it with a shifting of column values. I'll have to hook up a keypad and try it out.
Is there any tool which convert Verilog code to VHDL ?
@sunbelt57,
What is the problem? You have mentioned everything and not the problem.
VHDL and Verilog compilers are there to test your code! Write a good testbench and test them.
