default program loader
Hi all....
i have a spartan-3e XC3S1600E fg320
I need the default program that is loaded into the spartan.
I feel that the pin that shows the spartan are incorrect...
tanks for your help..
Re: default program loader
v,
There is no "default program" for a FPGA (device) component.
Do you mean the bitstream file that is shipped with a particular evaluation board?  If so, we would need to know the board's name, part number, and manufacturer.  If it isn't a board from Xilinx, then you should contact who sold you that board?
Austin Lesea
Principal Engineer
Xilinx San Jose
hi..
when I turn on my spartan run a test program
I wish I could get this program because when I be programming my spartan pins do not respond one ... the first led (LD0) for my  R14 I get it, I have selected this locationand the LED does not respond ....
So would this test program to check the pin asiganacion ....
thanks ..
v,
What board do you have?
Austin Lesea
Principal Engineer
Xilinx San Jose
Historian
Historian
@vitelyuz wrote:
Hi all....
FPGAs don't have a "default program."
