Participant petercaddick
f_mkfs fails in 2018.3
I've been using the FATs f_mkfs in 2017.4. This worked with no problems.  I recently up-graded the project to 2018.3 and now this has stopped working. I can see that the f_mkfs function has been changed (see attachement 2) but what is odd is it appears to be failing because it no longer recognises the drive (see attachment 1).  I've checked the hw configuration and this is ok as far as I can tell (see attachment 3).  If I look to see why it get FR_NOT_READY I see from attachment 4 that it must be "Wrong lower layer implementation". I'm fairly certain of this because I can reconfigure the HW with the old 2017.4 and the SD card works fine. So why am I getting a wrong low layer implementation?
Re: f_mkfs fails in 2018.3
I've fixed this myself with  Res = f_mkfs("", FM_ANY, 0, work, sizeof work); It doesn't need the path!!
