floating point FIR filter
i want to design floating point FIR filter. it will include a floatin point multiplier obviously. since real numbers arent synthesiable in VHDL what should i do to design a floating point multiplier?
i will be grateful for help...
Instructor
Instructor
Re: floating point FIR filter
If this is your first FPGA or ASIC design, I would recommend a much simpler problem than a floating point multiplier design for your first go.  Work your way up over time -- from simpler items -- to a FP multiplier.
If you are an experienced designer, your first task is to define your design requirements for performance, precision, and accuracy.  FP multipliers are not all alike.
-- Bob Elkind
SIGNATURE:
Summary:
floating-point arithmetic units
"What should I do to design a floating-point multiplier?"
Buy one. And a floating point adder/subtractor, which in some respects is more complicated. These are seriously complicated things. Remember, Intel got floating-point units wrong twice!
"If it don't work in simulation, it won't work on the board."
Professor
Professor
Re: floating-point arithmetic units
Actually multiplication is the easiest part of floating point arithemetic.  Addition is much harder
because it requires normalization.  Multiplication consists of:
multiplying the mantissas
adding the exponents
range and error checking
I thought there was a synthesizable floating point package for VHDL?
-- Gabor
-- Gabor
Instructor
Instructor
Actually multiplication is the easiest part of floating point arithemetic.  Addition is much harder because it requires normalization.
  • Both require rounding (which rounding modes?) and post-rounding normalisation.
  • Add/sub requires both unbounded alignment (before add/sub) and normalisation (after add/sub)
  • There are abundant datapath size/speed/routing tradeoffs to be made
If you seek to support the full suite of IEEE-754 "features" and compatibility, your troubles have just begun.  You will be wasting your youth while running regression tests for design verification.
Do we have your attention yet?
-- Bob Elkind
SIGNATURE:
Summary:
there's a FloatingPoint Operator available in Coregen that performs a number of Float operations.
Also there's a limited support of Float operations in sysgen from Version 13.4 on.
So there shouldn't be the need for designing the operators (Multiply, add, normalize etc) by yourself.
While the need for  float numbers in a FIR might be doubted (Do you really need that high dynamic range? Will your design still be fast and small enough? ) it might be interesting to see how things change over time. FPGAs are getting bigger, Tools getting smarter and once VHDL-2008 becomes supported by the synthesis tools with all the cool new packages (float, fixed, numeric_unsigned) will once again improve productivity. If its for better or for worse time will show.
So, make your experience with floating point designs, and tell us about your progress and problems.
But please don't complain that you haven't been warned that there's "danger ahead" by the people of this forum.
Have a nice synthesis
  Eilert
eteam00: you have all my attention . i am not an experiences designer but i have dont small bitts so thaught to work something complicated. this seems not compliated to me in starting but going throught his discussion it looks like i took a wrong step but not a problem . failure is not a problem although i will try my level best to go through it.
Professor
Professor
Actually the original post said nothing about IEEE-754, as well it should not.  Personally I believe that
the IEEE specification is bloated and originally pushed by Intel to sell their floating point hardware, while
a much simpler implementation might have been adequate for software floating point.  In my first job
as an engineer, I wrote some assembly language programs for 8085 micros.  We bought the floating
point library from Intel, which pushed the code size beyond the size of EPROM in the product.  I
went through and took almost half of the code out of the library, including a lot of error checking
and NaN handling that is of no use for embedded systems.  For something as straightforward
as a FIR filter, you don't need the full IEEE-754 (some will argue of course that you don't even need
floating point), just "scaled" numbers.  You can pick the size of the exponent and mantissa to
avoid overflow, and truncate to zero on underflow.  You still need to align and normalise numbers
for addition, but multiplication should result in already normalised results (or zero).  I don't think
that scaled numbers present on overly hard problem even for implementation in an FPGA.
-- Gabor
-- Gabor
thanks for such a good insight into the matter
