Observer shivanipatel
generating 8 clock outputs each shifted by one clock pulse w.r.to preceeding pulse
Hi All,
I want to generate a serial to parallel register in vhdl which will take clock input with 2 ms clock period and generate 8 clock outputs each shifted by one clock pulse w.r.to preceeding clock output with 8 ms clock period each.
Looking for the suggestions..
Thanx in advance
Teacher eteam00
Re: generating 8 clock outputs each shifted by one clock pulse w.r.to preceeding pulse
What is the frequency of the clock outputs?  Are all 8 outputs the same frequency?
The 8 outputs are all delayed by 0, 2, 4, 6, 8, 10, 12, 14 mS, respectively?
- Bob Elkind
SIGNATURE:
Summary:
Scholar drjohnsmith
so how would you code a serial to parallel  shift register
Thanx for the replies........
yes the output signal are of same frequencies delayed by one clock pulse(i.e. 4 ms) from the preceding one..
Teacher eteam00
According to your original post, one clock period is 2mS, not 4mS.  Correct?
What frequency is your clock output?
You will be using 8 output pins for your 8 clocks, correct?
-- Bob Elkind
SIGNATURE:
Summary:
Here my input clock signal is of 2ms(500Hz) clock period....
I needed 8 output signals with freq. (input/4=125 Hz(8 ms clock period)).i.e. each pulse width is of 4ms.
By delay of 4ms i mean to say was.......
outtput2 will be delayed from output1 by 4ms(one pulse)...similarly outtput3 will be delayed from output2 by 4ms and so on.....
Scholar drjohnsmith
some one once said
a picture is worth a 1000 words
can you draw and submirt a timing diagram of what you want ?
::))right said....
anyway...i got my output which i wanted.....thanx for replies
Scholar drjohnsmith
well done
can you post your answer so others in the future can benifit please,
Sure....
entity shift is
  port(ck: in std_logic;
       ck_stepin: inout std_logic;
       ck_steps: inout std_logic_vector(7 downto 0);
       ck_out : inout std_logic;
       ck_gt : inout std_logic);
end shift;
architecture archi of shift is
-------Input signal freq of the board is 32 MHz depending on which i have choosen the below dividing factor to convert it to 500 Hz------------
  signal ct_500: std_logic_vector(19 downto 0);-----counter
  signal ck_500: std_logic_vector(19 downto 0):= "00000111110011111111";Dividing factor which gives the 500 Hz pulse
  signal wrap: std_logic:= 0;
egin
    process (ck)
      begin
         if (ck'event and ck= '1') then
            if (ct_500 = ck_500) then
                     wrap <= not wrap;
                ct_500 <= (OTHERS => '0');
          else
                     ct_500 <= ct_500+ 1;
          end if;
  end process;
ck_out <= wrap;
--------this process generates 250 Hz signal(4 ms clock period)------
process (ck)
begin
    if (ck_out'event and ck_out = '1') then
       ck_gt <= not ck_gt;
    end if;
end process;
--------this process generates 125 Hz signal(8 ms clock period)------
process (ck)
begin
   if (ck_gt'event and ck_gt = '1') then
       ck_stepin <= not ck_stepin;
   end if;
end process;
-----this process generates the 8 output signals(of 8 ms clock period) each shifted by one clock pulse w.r.to 500 Hz signal----
process (ck)
begin
       ck_steps(7 downto 1) <=  ck_steps(6 downto 0);
        ck_steps(0) <= ck_stepin;
    end if;
end process;
end archi;
Have a nice day:)
